Full Version: DVD playback intermittently slowing down then resuming normal speed
This happens on every DVD, while playing the video will at regular intervals appear to slow down or lag then resume normal playback speed (audio doesn't seem to be affected by this). It is not random, at any given time in a movie it will always happen at those times in that movie. The lag lasts a couple of seconds or so then play normally for maybe 10 seconds, and repeat.
This issue doesn't appear at all in 16.1. For those analyzing the log, it happens on the same movie from the hard drive. I have an external TV hooked up, happens on either display, or without the TV using the laptop's monitor, or full screen or windowed. Altering the display buffer setting between 3 and 2 had no effect. The computer is more than capable of playing DVDs and Blu-rays, and there is nothing else using the CPU or memory besides the OS.
http://pastebin.com/LiCKSF8a
Kodi 17 RC2
Windows 7 SP1 64-bit
i5-2410M / 8GB DDR3
Video card: Intel HD Graphics 3000 / 15.28.24.64.4229
Sound card: IDT HIgh Definition Audio / 6.10.6492.0
Also reproducible on my desktop:
Kodi 17 RC2
i7-6700K / 16GB DDR4
GeForce GTX 1060
i have same problem but with all the AVI files, this is a example specs:
Quote:General
Complete name : xxxxxxx.avi
Format : AVI
Format/Info : Audio Video Interleave
File size : 345 MiB
Duration : 44 min 43 s
Overall bit rate mode : Variable
Overall bit rate : 1 077 kb/s
Writing application : VirtualDubMod 1.5.10.2 (build 2540/release)
Writing library : VirtualDubMod build 2540/release
Video
Format : MPEG-4 Visual
Format profile : Advanced [email protected]
Format settings, BVOP : No
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (MPEG)
Codec ID : XVID
Codec ID/Hint : XviD
Bit rate : 949 kb/s
Width : 624 pixels
Height : 352 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.173
Stream size : 304 MiB (88%)
Writing library : XviD 1.2.1 (UTC 2008-12-04)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Variable
Bit rate : 112 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Stream size : 36.9 MiB (11%)
Alignment : Aligned on interleaves
Interleave, duration : 26 ms (0.65 video frame)
Interleave, preload duration : 166 ms
Writing library : LAME3.90.
Encoding settings : -m j -V 4 -q 2 -lowpass 16 --abr 112
so, i think there is a problem with UI of the player probable memory leak, because when the movie starts to slow down (after usually every 10/15 minutes)
if i try to show the player controls (paure rewind etc..) (also without pause movie), the movie immediately begins to return fluid without problems.
My system is a dedicated HT computer:
Intel Core 2 Duo E6300
2 gb ram
Windows 10 Pro
Kodi Krypton 17.0 RC3
And play movie always throught DLNA with USB Wi-Fi AC 1600
NOTE: i don't have problem to play MKV at 1080P of 10GB....
It still occurred with RC3 but starting completely from scratch seemed to have fixed it.
Well, at least if I disable "Allow hardware acceleration - DXVA2" on the laptop but the desktop works fine with it enabled.
mmh it would be inappropriate disable DXVA2, at least in my case,
i have a AMD HD 6670 and it support DXVA2
i can try perhaps temporany solution...
