(2017-07-20, 08:24)badaas Wrote: [ -> ]What version colorbox is installed?
Need this: https://github.com/BADMS/script.colorbox
2.0.2 on krypton, and current master HEAD on leia. It works with what I posted, but doesn't with what you posted.
Unrelated and not sure if known: I've found the colorbox script doesn't work on libreelec ARM devices, but haven't got anything useful in debug logs. It states the script runs, but there's nothing after.
Probably no PILLOW module.
I'll have to look later at skin, it works fine in adonic, so maybe dig a little deeper, it's all there
(2017-07-21, 00:04)badaas Wrote: [ -> ]What are you testing on?
The runscript onunfocus route that works for me, works on both krypton and leia on x86_64 Linux. The other one you posted (included in the commit two posts ago) doesn't work on either. Adonic works on this setup however, so I believe I'm missing something in the implementation.
I haven't been testing on LibreELEC ARM because colorbox doesn't work on either libreelec 9 (leia) or libreelec 8 (krypton), including on adonic.
EDIT: Sorry wrong thread!
I can't figure out how this script works.
I want to have a blurred posterart as background for the homescreen and the DialogVideoInfo screen on the estuary skin.
Lines for the background on the home screen:
<control type="multiimage">
<depth>DepthBackground</depth>
<include>FullScreenDimensions</include>
<aspectratio>scale</aspectratio>
<fadetime>600</fadetime>
<animation effect="zoom" center="auto" end="102,102" time="0" condition="Integer.IsGreater(System.StereoscopicMode,0)">conditional</animation>
<animation effect="fade" start="0" end="100" time="400">WindowOpen</animation>
<animation effect="fade" start="100" end="0" time="300">WindowClose</animation>
<animation effect="fade" time="400">VisibleChange</animation>
<imagepath background="true" colordiffuse="bg_overlay">$VAR[HomeFanartVar]</imagepath>
<visible>!Player.HasMedia</visible>
</control>
Background line for the DialogVideoInfo:
<onload>SetProperty(infobackground,$ESCINFO[ListItem.Art(poster)],home)</onload>
Could you please help me?
