2017-01-14, 07:12
Hey guys,
i wanted upgrade from Jarvis to Krypton but VDR/PVR dont work. Heres an output:
I tried the Addon from the nightly ppa, still the same:
Did someone got a solution? I switch now back to Jarvis because this is my main system - and a day without TV su.......
Thx
05:41:29.766 T:140257084176384 NOTICE: special://profile/ is mapped to: special://masterprofile/
05:41:29.766 T:140257084176384 NOTICE: -----------------------------------------------------------------------
05:41:29.766 T:140257084176384 NOTICE: Starting Kodi (17.0-RC3 Git:20170112-nogitfound). Platform: Linux x86 64-bit
05:41:29.766 T:140257084176384 NOTICE: Using Release Kodi x64 build
05:41:29.766 T:140257084176384 NOTICE: Kodi compiled Jan 12 2017 by GCC 4.8.4 for Linux x86 64-bit version 3.13.11 (199947)
05:41:29.766 T:140257084176384 NOTICE: Running on Ubuntu 14.04.5 LTS, kernel: Linux x86 64-bit version 3.16.0-77-generic
05:41:29.766 T:140257084176384 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
05:41:29.766 T:140257084176384 NOTICE: Host CPU: AMD A4-5300 APU with Radeon(tm) HD Graphics, 2 cores available
05:41:29.766 T:140257084176384 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
05:41:29.766 T:140257084176384 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi
05:41:29.766 T:140257084176384 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/x86_64-linux-gnu/kodi/addons
05:41:29.766 T:140257084176384 NOTICE: special://masterprofile/ is mapped to: /home/loki/.kodi/userdata
05:41:29.766 T:140257084176384 NOTICE: special://envhome/ is mapped to: /home/loki
05:41:29.766 T:140257084176384 NOTICE: special://home/ is mapped to: /home/loki/.kodi
05:41:29.766 T:140257084176384 NOTICE: special://temp/ is mapped to: /home/loki/.kodi/temp
05:41:29.766 T:140257084176384 NOTICE: special://logpath/ is mapped to: /home/loki/.kodi/temp
05:41:29.766 T:140257084176384 NOTICE: The executable running is: /usr/lib/x86_64-linux-gnu/kodi/kodi.bin
05:41:29.766 T:140257084176384 NOTICE: Local hostname: mediapc
05:41:29.766 T:140257084176384 NOTICE: Log File is located: /home/loki/.kodi/temp//kodi.log
05:41:29.779 T:140257084176384 NOTICE: load settings...
05:41:29.815 T:140257084176384 NOTICE: Found 1 Lists of Devices
05:41:29.815 T:140257084176384 NOTICE: Enumerated PULSE devices:
05:41:29.815 T:140257084176384 NOTICE: Device 1
05:41:29.815 T:140257084176384 NOTICE: m_deviceName : Default
05:41:29.815 T:140257084176384 NOTICE: m_displayName : Default
05:41:29.815 T:140257084176384 NOTICE: m_displayNameExtra: Default Output Device (PULSEAUDIO)
05:41:29.815 T:140257084176384 NOTICE: m_deviceType : AE_DEVTYPE_PCM
05:41:29.815 T:140257084176384 NOTICE: m_channels : FL,FR
05:41:29.815 T:140257084176384 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
05:41:29.815 T:140257084176384 NOTICE: m_dataFormats : AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
05:41:29.815 T:140257084176384 NOTICE: m_streamTypes : No passthrough capabilities
05:41:29.815 T:140257084176384 NOTICE: Device 2
05:41:29.815 T:140257084176384 NOTICE: m_deviceName : alsa_output.pci-0000_00_01.1.hdmi-stereo
05:41:29.815 T:140257084176384 NOTICE: m_displayName : Internes Audio Digital Stereo (HDMI)
05:41:29.815 T:140257084176384 NOTICE: m_displayNameExtra: HDMI / DisplayPort (PULSEAUDIO)
05:41:29.815 T:140257084176384 NOTICE: Device 3
05:41:29.815 T:140257084176384 NOTICE: m_deviceName : alsa_output.pci-0000_00_14.2.analog-stereo
05:41:29.815 T:140257084176384 NOTICE: m_displayName : Internes Audio Analog Stereo
05:41:29.815 T:140257084176384 NOTICE: m_displayNameExtra: Analoge Ausgabe (PULSEAUDIO)
05:41:29.818 T:140257084176384 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
05:41:29.818 T:140257084176384 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
05:41:29.818 T:140257084176384 NOTICE: Default Video Player: VideoPlayer
05:41:29.818 T:140257084176384 NOTICE: Default Audio Player: paplayer
05:41:29.818 T:140257084176384 NOTICE: Disabled debug logging due to GUI setting. Level 0.
05:41:29.818 T:140257084176384 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
05:41:29.818 T:140257084176384 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
05:41:29.818 T:140257084176384 NOTICE: Loaded playercorefactory configuration
05:41:29.818 T:140257084176384 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
05:41:29.818 T:140257084176384 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
05:41:29.823 T:140257084176384 NOTICE: Running database version Addons26
05:41:29.947 T:140257084176384 NOTICE: ADDONS: Using repository repository.xbmc.org
05:41:29.957 T:140256577840896 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms
05:41:30.049 T:140257084176384 NOTICE: Checking resolution 16
05:41:30.140 T:140257084176384 ERROR: Failed to determine egl config for visual info
05:41:30.140 T:140257084176384 WARNING: Visual 0x29 of the window is not suitable, looking for another one...
05:41:30.140 T:140257084176384 NOTICE: Using visual 0x23
05:41:30.150 T:140257084176384 NOTICE: Using visual 0x29
05:41:30.160 T:140257084176384 NOTICE: GL_VENDOR = ATI Technologies Inc.
05:41:30.160 T:140257084176384 NOTICE: GL_RENDERER = AMD Radeon HD 7480D
05:41:30.160 T:140257084176384 NOTICE: GL_VERSION = 4.5.13399 Compatibility Profile Context 15.201.1151
05:41:30.160 T:140257084176384 NOTICE: GL_SHADING_LANGUAGE_VERSION = 4.40
05:41:30.160 T:140257084176384 NOTICE: GL_EXTENSIONS = GL_AMDX_debug_output GL_AMDX_vertex_shader_tessellator GL_AMD_blend_minmax_factor GL_AMD_conservative_depth GL_AMD_debug_output GL_AMD_depth_clamp_separate GL_AMD_draw_buffers_blend GL_AMD_framebuffer_sample_positions GL_AMD_multi_draw_indirect GL_AMD_name_gen_delete GL_AMD_performance_monitor GL_AMD_pinned_memory GL_AMD_query_buffer_object GL_AMD_sample_positions GL_AMD_seamless_cubemap_per_texture GL_AMD_shader_atomic_counter_ops GL_AMD_shader_stencil_export GL_AMD_shader_trace GL_AMD_texture_cube_map_array GL_AMD_texture_texture4 GL_AMD_transform_feedback3_lines_triangles GL_AMD_vertex_shader_layer GL_AMD_vertex_shader_tessellator GL_AMD_vertex_shader_viewport_index GL_ARB_ES2_compatibility GL_ARB_ES3_1_compatibility GL_ARB_ES3_compatibility GL_ARB_arrays_of_arrays GL_ARB_base_instance GL_ARB_blend_func_extended GL_ARB_buffer_storage GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control GL_ARB_color_buffer_float GL_ARB_compatibility GL_ARB_compressed_texture_pixel_storage GL_ARB_compute_shader GL_ARB_conditional_render_inverted GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_copy_image GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_draw_indirect GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB GL_ARB_geometry_shader4 GL_ARB_get_program_binary GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64 GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_instanced_arrays GL_ARB_internalformat_query GL_ARB_internalformat_query2 GL_ARB_invalidate_subdata GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_program_interface_query GL_ARB_provoking_vertex GL_ARB_query_buffer_object GL_ARB_robust_buffer_access_behavior GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding GL_ARB_shader_image_load_store GL_ARB_shader_image_size GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_shader_stencil_export GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader GL_ARB_texture_barrier GL_ARB_texture_border_clamp GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32 GL_ARB_texture_buffer_range GL_ARB_texture_compression GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_rgb10_a2ui GL_ARB_texture_snorm GL_ARB_texture_stencil8 GL_ARB_texture_storage GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_envmap_bumpmap GL_ATI_fragment_shader GL_ATI_meminfo GL_ATI_separate_stencil GL_ATI_texture_compression_3dc GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_ATI_texture_mirror_once GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_copy_buffer GL_EXT_copy_texture GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4 GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4 GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset_clamp GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texgen_reflection GL_EXT_texture3D GL_EXT_texture_array GL_EXT_texture_buffer_object GL_EXT_texture_compression_bptc GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_integer GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_shared_exponent GL_EXT_texture_snorm GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_transform_feedback GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug GL_KHR_robust_buffer_access_behavior GL_KHR_robustness GL_KTX_buffer_region GL_NV_blend_square GL_NV_conditional_render GL_NV_copy_depth_to_color GL_NV_copy_image GL_NV_depth_buffer_float GL_NV_explicit_multisample GL_NV_float_buffer GL_NV_half_float GL_NV_primitive_restart GL_NV_texgen_reflection GL_NV_texture_barrier GL_OES_EGL_image GL_SGIS_generate_mipmap GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays GL_WIN_swap_hint
05:41:30.256 T:140257084176384 ERROR: Window Translator: Can't find window tv
05:41:30.297 T:140256519091968 NOTICE: Running database version Addons26
05:41:30.297 T:140256519091968 NOTICE: Running database version ViewModes6
05:41:30.298 T:140256519091968 NOTICE: Running database version Textures13
05:41:30.299 T:140256519091968 NOTICE: Running database version MyMusic60
05:41:30.301 T:140256519091968 NOTICE: Running database version MyVideos107
05:41:30.302 T:140256519091968 NOTICE: Running database version TV29
05:41:30.302 T:140256519091968 NOTICE: Running database version Epg11
05:41:30.303 T:140257084176384 NOTICE: start dvd mediatype detection
05:41:30.315 T:140257084176384 WARNING: CSkinInfo: failed to load skin settings
05:41:30.382 T:140257084176384 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
05:41:30.460 T:140257084176384 NOTICE: initialize done
05:41:30.460 T:140257084176384 NOTICE: Running the application...
05:41:30.462 T:140257084176384 NOTICE: starting zeroconf publishing
05:41:30.462 T:140257084176384 NOTICE: starting upnp client
05:41:30.485 T:140255235663616 NOTICE: ES: Starting UDP Event server on port 9777
05:41:30.485 T:140255235663616 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
05:41:38.406 T:140256519091968 ERROR: GetDirectory - Error getting
05:41:43.112 T:140257084176384 ERROR: Previous line repeats 2 times.
05:41:43.112 T:140257084176384 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.2.6.11
05:41:43.112 T:140257084176384 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
06:03:14.769 T:139967997401088 ERROR: ADDON: Could not locate pvr.vdr.vnsi.so.3.0.2
06:03:14.769 T:139967997401088 ERROR: UpdateAddons - failed to create add-on VDR VNSI Client, status = 6
Thx
