2017-01-15, 21:33
2017-01-16, 02:31
maybe I didn't explain myself very well , Seeing as there is no option ( that i can see anyway ) in settings to either set backgrounds for each menu item or set multiple global backgrounds other than random default ones , i wanted to use one global background and set each tile to have multiple thumbnails is this possible please ?
2017-01-17, 01:21
Yes, that's exactly possible with Titan. You can configure almost everything.
Please note that the option for multiple images inside the tiles is only supported in the beta version atm
2017-01-17, 01:36
i tried multiple image sizes but can't get any to fit inside the tiles , i even went into kodi folders and looked at the size of the default tile images 623x271 , resized a few of mine but none of them fit am afraid. dose is give you multiple images option in the settings of the beta version when selecting thumbnail for main menu item ?
2017-01-17, 01:45
What homelayout are you using ?
2017-01-17, 11:00
tried both 2xrows large tiles and 2xrows small tiles
