(2017-03-29, 03:58)knives of ice Wrote: [ -> ]finally pulled the trigger on an LG Oled 4k tv and i've never used my shield with a 4k tv thus far. can the shield playback 2160p 10bit x265 files? i wasn't sure about this since i never had the need to try in the past
Yes, it should play them back fine, with HDR if the file has it (I have the same combo) Make sure the HDMI input the Shield is plugged into is setup for "Deep Color" on the LG OLED.
(2017-03-29, 04:02)SootAndPooh Wrote: [ -> ] (2017-03-23, 03:34)cscoppa Wrote: [ -> ]I use 10 bit BT.2020 on the shield with resolution set to 4K. I tend to flip back and forth. (1080p for cable and "normal" content and 4K for UHD files) I noticed if I change just the resolution the Shield auto picks the appropriate color space saving a bit of time. The reason I switch is so I can use the TV's upscaler and also for my AVR's on screen volume indicator which won't overlay on top of 4K. The one catch with SPMC is the MediaCodec (Surface) hardware acceleration option HAS to be on for HDR to work. (You need to have it off to use SPMC's high quality scalers like Lanczos3)
Also I don't do any refresh rate switching. I leave it at 60 and let the tv do the "5 frames" thing. (120 divided by 24 = 5 frames each) I set dejudder to 2 or 3 and deblur to 0.
Cheers for those suggestions cscoppa. Leaving refresh rate switching off is the only way I can get the 24p files to play without colour banding. While those dejudder settings help I still notice the judder which I don't get if I play the content directly though the TV USB (but then no HD audio passthrough to my soundbar) or if I set SPMC to output it at 24Hz (but then I get colour banding). Starting to think no perfect solution at this stage.
Have you tried TruMotion --> USER --> both set to 0? Also might be worth trying Krypton 17.1 just to see if it changes anything.
Hello .
Can change download path Add-on (Artwork Downloader)
To download ExtraFanart In the same folder movie in External HDD ? .
download ExtraFanart In the same folder movie default in other devices
But in Shield download In internal memory !!
(2017-03-29, 16:28)cscoppa Wrote: [ -> ] (2017-03-29, 03:58)knives of ice Wrote: [ -> ]finally pulled the trigger on an LG Oled 4k tv and i've never used my shield with a 4k tv thus far. can the shield playback 2160p 10bit x265 files? i wasn't sure about this since i never had the need to try in the past
Does HDR playback works with Kodi as well?
(2017-04-04, 07:53)Caramba69 Wrote: [ -> ] (2017-03-29, 16:28)cscoppa Wrote: [ -> ] (2017-03-29, 03:58)knives of ice Wrote: [ -> ]finally pulled the trigger on an LG Oled 4k tv and i've never used my shield with a 4k tv thus far. can the shield playback 2160p 10bit x265 files? i wasn't sure about this since i never had the need to try in the past
Yes, if it's encoded into the file correctly. (HDR10)
Ah, skins. Aeon Nox is fine (haven't tried MQ) but one annoying bit is that I can never seem to get artist slideshow to work. Does anyone know the right settings and install options for ANY skin (I'm not too bound to Aeon) for this to work?
I'm going nuts today because SPMC on my shield gets timed out error messages for all my Windows SMB shares. I do not have this problem at all with my LiberElec Chromebox.
any idea what could be causing this problem? i've never had it before and don't understand why it would occur with one box and not all of them on my network
(2017-04-07, 00:31)knives of ice Wrote: [ -> ]I'm going nuts today because SPMC on my shield gets timed out error messages for all my Windows SMB shares. I do not have this problem at all with my LiberElec Chromebox.
Not without at least a
Debug log (wiki).
That said, if you're using a wired connection check/change your ethernet cables. If you're using wifi, change the location of your Shield to see if you're getting interference or change to a wired connection.
(2017-04-07, 01:04)Tinwarble Wrote: [ -> ] (2017-04-07, 00:31)knives of ice Wrote: [ -> ]I'm going nuts today because SPMC on my shield gets timed out error messages for all my Windows SMB shares. I do not have this problem at all with my LiberElec Chromebox.
Not without at least a Debug log (wiki).
i'm using a wired connection, no problem at all with it as other apps like netflix work fine
i made the suggested changes here
http://kodi.wiki/view/SMB/Windows#Timeout and they didn't help
here is my debug log
https://paste.ubuntu.com/24331222/
this is on a brand new install of Kodi on my shield, i have the same problem with SPMC
EDIT ----- FIXED
I just got a new 24 port Dlink switch. didn't realize there is some type of security toggle on it that would screw up file sharing settings. flicked this just to see if it would fix the problem and for some reason it did. not sure why this effects Android and not the chromebox but it did
I'm looking for Shield remote but not orginal but something similar with voice search built in mic, and on/off power button something like remote from MiBox 4K. Someone recomend any ?
anyone have any files that they know are HDR? i have some 2160p files that i assumed would show as HDR. i guess i'm not 100% certain i have things etup correctly in SPMC to ensure HDR files play correctly or even if there is a way to tell if my file is HDR
(2017-04-09, 04:18)Tinwarble Wrote: [ -> ]Check Samples (wiki) in the wiki.
thanks so much for posting this.
ok, with my LG OLED anytime i playback an HDR file on netflix or amazon i get a notice in the upper right corner that says HDR. I can't get that notice to appear with any of these sample files. i copied all the recommended settings for SPMC here
https://github.com/koying/SPMC/wiki/Reco...ith-4K-GUI
except i don't have video scaling method = lanczos3 - optimised listed at all as an option
EDIT - this ended up being my problem a note by Koying fixed things
"Note: with SPMC 16.6, you must disable MediaCodec (Surface) to use upscaling or deinterlacing. However, if you disable MediaCodec (Surface), then HDR content will not be displayed in HDR."
can anyone with an LG OLED confirm you get that HDR notifcation with any of the sample hdr files?
i have deep color set for the input my shield is on not sure what the problem could be
