2018-05-31, 18:47
(2018-05-31, 11:50)noggin Wrote: [ -> ]I can't find them now -
It had been discussed in THIS thread: https://forum.kodi.tv/showthread.php?tid...pid2689145
(2018-05-31, 19:53)hdmkv Wrote: [ -> ]Anyone using an Optoma 4K projector with Shield? Preferably UHD50 or the new UHD51A? I recently got the latter, and can’t get 10 or 12-bit output out of Kodi (using v18 Alpha 1) and 23.976 or 24.000. With 4K@60 HDR (like the Sony Camp demo clip), I get 10-bit 4:2:0. But, with 23.976, it’s always 8-bit 4:2:2.Shield only supports Deep Color at 4K 50/60Hz (10-bit 4:2:0). At lower refresh rates it is 8-bit 4:4:4 for Rec. 709 or 12-bit 4:2:2 for Rec. 2020. The 8-bit that you are seeing on your projector or AVR is unlikely to be true. There are very few devices that can accurately detect the bit depth of 4:2:2 signal. Most of them display 8-bit (including some HDMI analyzers and HD Fury Vertex).
With Zidoo X9S and new X20, with 23.976, I get 4:4:4 12-bit as expected. Can’t figure out why Shield won’t do same?
(2018-05-31, 11:50)noggin Wrote: [ -> ](wish we'd call it gamut conversion to distinguish from 'same primary' colour space conversion like 601<->709)
@wesk05 should be able to tell us - I think he's done some proper analysis of the previous 709->2020 gamut conversion that the Shield TV did. (Reporting back that it wasn't perfect but that it was better than some feared ISTR)
(2018-05-31, 22:11)wesk05 Wrote: [ -> ]As a matter of principle I do not enter into NDAs, the terms of which I don't have full knowledge of.
(2018-05-31, 22:21)Tinwarble Wrote: [ -> ]There's no NDA for the Preview program, they only ask that you don't discuss thing mentioned in the Preview forum outside the Preview forum. Though, as you can see from the regular forum, many people don't even do that. Nvidia themselves don't even always follow their own rules.
But there's nothing that you have to sign and no consequences for breaking that rule.
(2018-05-31, 22:42)wesk05 Wrote: [ -> ]I consider putting limitations on communication as one of the terms in a NDA. There may not be a proper NDA to sign and because of that this limitation on communication may not even have legal validity. By joining the Preview program, you agree to the SHIELD software license agreement and thereby to the Beta Program supplement in that agreement. I also consider it as a waste of time, since these beta or preview releases are really release candidates. It's for all these reasons that I decided not to participate in this program.
(2018-05-31, 23:11)Tinwarble Wrote: [ -> ]I understand your reasoning behind not wanting to be in the program, but it seems mostly arbitrary. It's your choice though, and wouldn't try and convince you otherwise. I guess it really just comes down to if you want it early or just want to wait until it goes to general release.Fair enough! I'm in no hurry to get the update
(2018-05-31, 21:53)wesk05 Wrote: [ -> ]Thanks, I'll try the test pattern... can you point me to the post where I can download it? I did a full forum search on "2DQuants" and "wesk05" and only above post came up.(2018-05-31, 19:53)hdmkv Wrote: [ -> ]Anyone using an Optoma 4K projector with Shield? Preferably UHD50 or the new UHD51A? I recently got the latter, and can’t get 10 or 12-bit output out of Kodi (using v18 Alpha 1) and 23.976 or 24.000. With 4K@60 HDR (like the Sony Camp demo clip), I get 10-bit 4:2:0. But, with 23.976, it’s always 8-bit 4:2:2.Shield only supports Deep Color at 4K 50/60Hz (10-bit 4:2:0). At lower refresh rates it is 8-bit 4:4:4 for Rec. 709 or 12-bit 4:2:2 for Rec. 2020. The 8-bit that you are seeing on your projector or AVR is unlikely to be true. There are very few devices that can accurately detect the bit depth of 4:2:2 signal. Most of them display 8-bit (including some HDMI analyzers and HD Fury Vertex).
If you do want to confirm whether your projector is treating the signal as 8-bit or 12 (10)-bit, check it out with one of the 2DQuants test pattern that I mentioned in my previous post. If the signal is being processed as 10/12-bit 4:2:2, you should see something like in this picture- https://imgur.com/wqAlDRk . You will see 4 block wide bands, if it is processed as 8-bit as you can see in the preview below:
(2018-06-01, 00:57)hdmkv Wrote: [ -> ] Thanks, I'll try the test pattern... can you point me to the post where I can download it? I did a full forum search on "2DQuants" and "wesk05" and only above post came up.
(2018-06-01, 03:44)hdmkv Wrote: [ -> ]Thanks, of course now I recall that thread/post . So, just tested both the Cb & Cr light gray patterns in the HDR10 folder...
...and the results look very similar, if not the same. Zidoo's looks cleaner, but both look closer to the 8-bit screenshot you posted above. Not completely solid gray as it should be.
(2018-06-01, 03:44)hdmkv Wrote: [ -> ]Thanks, of course now I recall that thread/post . So, just tested both the Cb & Cr light gray patterns in the HDR10 folder...@wesk05 @hdmkv
With nVidia Shield TV:
With Zidoo X9S & X20:
(2018-06-01, 04:18)wesk05 Wrote: [ -> ]Okay, just tested all 4 light gray samples in the BT.2020 folder...(2018-06-01, 03:44)hdmkv Wrote: [ -> ]Thanks, of course now I recall that thread/post . So, just tested both the Cb & Cr light gray patterns in the HDR10 folder...
I forgot to mention, try the non-HDR ones in the BT.2020 folder.
