On some systems Kodi Interface Sounds can be too loud compared to media volume. Depending on your hardware setup and media source, big difference in loudness may cause discomforting or even painful experience. To solve this I have created two sound add-ons with reduced UI volume, using Audacity:
- Kodi UI Sounds (-12 dB) [50% original volume] Mega | Dropbox
- Kodi UI Sounds (-24 dB) [25% original volume] Mega | Dropbox
After downloading the above files, simply go to
Settings → Add-ons → Install from zip
and enable one in
Settings → System → Audio
. Restart Kodi and you're done.
Of course it would be much more convenient to have quiet sounds available from the Official Kodi.tv Repository, but I cannot publish there myself. If anyone wants to upload them — please do so. Thank you!
Thanks to @scott967 for his help.
# audio volume level loud loudness high higher click back forward control select selection sudden suddenly sound decibel db ear ears hearing clipping clips clipped speakers headphones earphones annoying pain painful hurts low lower quiet quieter ui gui interface addon add-on plugin plug-in tweak bug solved fix enhance enhancement choice setting settings option options preference preferences link download dl upload find publish published release released repository repo list listed
thank you
this should be included per default cause the ones right now are way too loud.
Hmmm, links no longer working...
(2017-07-25, 10:52)cizzz Wrote: [ -> ]Hmmm, links no longer working...
Thanks for pointing this out! I've updated Dropbox links and added a mirror.
(2017-01-16, 12:24)pure.by Wrote: [ -> ]On some systems Kodi Interface Sounds can be too loud compared to media volume. Depending on your hardware setup and media source, big difference in loudness may cause discomforting or even painful experience. To solve this I have created two sound add-ons with reduced UI volume, using Audacity:
After downloading the above files, simply go to Settings → Add-ons → Install from zip
and enable one in Settings → System → Audio
Hi, it seems all the links are dead, does anyone have a working link / copy of this releases?
(2021-10-30, 15:18)cdspam Wrote: [ -> ] (2017-01-16, 12:24)pure.by Wrote: [ -> ]On some systems Kodi Interface Sounds can be too loud compared to media volume. Depending on your hardware setup and media source, big difference in loudness may cause discomforting or even painful experience. To solve this I have created two sound add-ons with reduced UI volume, using Audacity:
No, but I could probably roll my own. Give me a bit to work on it.
scott s.
(2021-10-31, 01:23)scott967 Wrote: [ -> ] (2021-10-30, 15:18)cdspam Wrote: [ -> ] (2017-01-16, 12:24)pure.by Wrote: [ -> ]On some systems Kodi Interface Sounds can be too loud compared to media volume. Depending on your hardware setup and media source, big difference in loudness may cause discomforting or even painful experience. To solve this I have created two sound add-ons with reduced UI volume, using Audacity:
scott s.
That would be brilliant, thank you
That's great, thanks so much!.
I will give them a try and see how they sound
pure.by , @
scott967
I want a MC sans noise, distraction & nonsense and have therefore always set Kodi to silent. However, I need sounds in two situations:
- ALWAYS: when taking screenshots.
- WHEN DEBUGGING: alert & notifications sounds.
I suppose I could achieve this sound profile by removing some mounds & editing sounds.xml from your add-on?
Could I do the same customizing the defaults? The sounds files/xml in skin folder don't do the job.
