Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17
np for me, i just test leia from time to time and see this issue
Great.
Do you experience the same issue in Krypton?
no that would make me angry as hell
Lol, I see.
Nothing in that matter should have changed between the 2 versions, but something must be up. So I'll look into it.
I'm sorry :/ still same problem.
Which nightly exactly?
It doesn't happen for me at all...
the nightly you posted before
hehe, i installed now all new. with a fresh installation all work. it have something to do with the configuration of my live system.
i'll give you a copy of my skin settings.
How do you switch channels?
Is it via a remote or the OSD buttons?
If it's a remote, which command do you use? PlayerControl(Next) / PlayerControl(Previous)?
It's up and down via Remote Control. But same issue if i switch by keyboard.
Just tried with your skin settings and no issues at all.
I'm pretty positive it's not a skin issue.
Could it be a problem with DVBViewer? I don't use that addon and have no way to test it.
Since it work with a new installation i will make a fresh install if leia be beta.
2 hours of scraping + resynch with trakt.tv will fix it. thanks a lot.
