Full Version: Music widget in custom window.. only show info
So I have playlist as the content for a widget in my discover window.. the problem I am having is if I press enter or p for play it does nothing... I can only get a response from I for info. I want it to by default open mymusicnav.xml so the person can browse the album.. is there something simple I am missing to make this happen of do I have to be in the music library for it to work?
The playlist does work in the music library just putting that out there.
target="music"
This part is missing for you in content for widget...I think Smile
This will make play your song in player "onClick"
Thank you that worked perfect also got to get ride of a play list thank you.
