Full Version: vu+ pvr addon stopped working
Pages: 1 2 3
Hi,,,,
I have a version of Kodi 17.1 installed,for Windows 10.
1.Uninstall Kodi 17.1 from PC - local disk C-program files (86)
2.Download Kodi 17.3 from Kodi.TV-Download-Windows-Installer (32bit)
PVR IPTV Simple Client,,, Works perfectly
Tomorrow I will try for Linux Raspberry Pi3,Android beelink,phone,,,and VU+SOLO2
(2017-05-27, 21:59)dreamerds Wrote: [ -> ]Hi
I have a problem with kodi 17.3 and enigma pvr client. pvr is loading all channels but dont start play. Channels are listed to TV section, EPG its ok, but dont start playing. All is working with kodi 17.1, but 17.2-17.3 dont. settings on both programs are same.
Problem is same in windows, android, qnap nas. 17.1 Ok 17.2-17.3 dont.
Hi,,,,
(2017-05-28, 00:16)ZaroZaro Wrote: [ -> ]
Hi,,,,
VU+SOLO2
Kodi direct and Kodi launcher ,,,I can not install PVR IPTV Simple Client,
Hello, i have the Same problem under OpenSuse Tumbleweed, EPG and everything Looks Fine, But the Stream don't Start.
What can i do?
For me dont work to ( 800SE see HDD ) but dont streem
same here. cant play the channels. log below.
20:29:52.031 T:137878340688 NOTICE: VideoPlayer: Opening: pvr://channels/tv/All channels/pvr.vuplus_67.pvr
20:29:52.031 T:137878340688 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
20:29:52.032 T:138335478864 NOTICE: Creating InputStream
20:30:12.087 T:138335478864 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:30:20.149 T:138895668304 WARNING: No information found for item 'nfs://192.168.1.163/volume1/Video/TV Shows/@eaDir/', it won't be added to the library.
20:30:20.609 T:138895668304 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 03:20
20:30:32.097 T:138335478864 ERROR: CCurlFile::FillBuffer - Failed: Timeout was reached(28)
20:30:32.098 T:138335478864 NOTICE: Creating Demuxer
20:30:32.150 T:138335478864 ERROR: Open - error probing input format, http://192.168.1.148:8001/1:0:1:9B3:63:2...0000:0:0:0
20:30:32.170 T:138335478864 ERROR: Previous line repeats 9 times.
20:30:32.170 T:138335478864 ERROR: OpenDemuxStream - Error creating demuxer
20:30:32.170 T:138335478864 NOTICE: CVideoPlayer::OnExit()
20:30:32.242 T:137878340688 NOTICE: CVideoPlayer::CloseFile()
20:30:32.242 T:137878340688 NOTICE: VideoPlayer: waiting for threads to exit
20:30:32.242 T:137878340688 NOTICE: VideoPlayer: finished waiting
20:31:05.113 T:138334413904 NOTICE: My Music: Scanning for music info using worker thread, operation took 04:04
20:31:25.824 T:138529371216 ERROR: AddOnLog: VU+ / Enigma2 Client: GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
20:32:37.018 T:137878340688 NOTICE: NFS is idle. Closing the remaining connections.
20:33:30.906 T:138529371216 ERROR: AddOnLog: VU+ / Enigma2 Client: GetRecordings Error fetching lists for folder: '/media/hdd/movie/'
wow, I love this thread. All users have the "same problem" on 2 pages, but no complete log until today
which receiver-OS, client-OS and which version of KODI are you using?
I've the Vu+ PVR client in combination with openATV running on Android and a few linux distributions (Ubuntu, LibreELEC and Gentoo) and versions < KODI 18 (only exception is 17.2) work as expected.
If you use KODI 18, then it's possible, that the old API version of the client doesn't work with the new API version of KODI 18 (bad news for all Vu+ users), otherwise I would check the usual suspects:
- Configuration of WebIf (security, http, anonymous). Since 2017 OpenWebIf based receivers have a new default setting, they allow anonymous access only from LAN, no longer from WAN
- Configuration of KODI (URL, Bouquets)
Receiver OS is latest OoenVix
Client OS is Android 7 on nvidia shield
Kodi version is 17.3
Sent from my Pixel XL
(2017-07-19, 12:55)zehner Wrote: [ -> ]wow, I love this thread. All users have the "same problem" on 2 pages, but no complete log until today
which log do you want exactly?
On my Reciver runs OpenATV 6.0 and my PC is a OpenSuse Tumbleweed System, the Kodi Version is kodi-17.3-1.7.x86_64
The install pvr-addon is this https://opensuse.pkgs.org/tumbleweed/pac...4.rpm.html
What can i do to run the PVR fine?
Here a few lines of Debug Log
https://pastebin.com/0WitCSRB
The Codec Error o don't understand ffmpeg is installed
No one a idea? Hav anybody a Kodi 16.x Version for OpenSuse?
Gesendet von iPhone mit Tapatalk
Hi, no one?
At least you have a pvr client. Kodi extension in VuSolo SE does not show PVR clients. May I ask you how you managed to do that? Which PVR client do you use? I need to install a m3u list. Or might there be a repository that offers PVR Simple Client?
Thankx.
Running on Krypton 17.4
Ronaldini
(2017-10-21, 18:54)Ronaldini Wrote: [ -> ]At least you have a pvr client. Kodi extension in VuSolo SE does not show PVR clients. May I ask you how you managed to do that? Which PVR client do you use? I need to install a m3u list. Or might there be a repository that offers PVR Simple Client?
Thankx.
Ronaldini
why do you want to run the Kodi PVR client on your enigma box?
With enigma you already have an optimal aligned OS for your PVR needs. The PVR client is only useful if you want to connect to your enigma machine from another box, compared to a pure enigma setup it has more disadvantages than advantages on an enigma box. Even for regular media I would use EMC or another Enigma based media center software, not KODI
Vu+/Enigma2 pvr was working on my Wetekplay2 few days back, but, now, it asking me addon couldn't be loaded, I have Vu+solo2, there is no other addon on kodi at the moment, any possible solution
(2017-11-15, 19:06)Rizwan awan Wrote: [ -> ]Vu+/Enigma2 pvr was working on my Wetekplay2 few days back, but, now, it asking me addon couldn't be loaded, I have Vu+solo2, there is no other addon on kodi at the moment, any possible solution
 Hi I seen on another forum to possibly change the port on your client from 80 to 00080
Might be worth a try.
Pages: 1 2 3
