Full Version: Geek & Sundry some videos wont play
Hello, I am setting up kodi for the first time on my media PC. I have installed the geek & sundry addon and have found that some videos will play and some will not. I can play the videos that wont load in kodi through chrome @ the geek & sundry site.
I am running on Windows 10 using Kodi Krypton and Geek & Sundry 0.1.6 (I had the same results using |Jarvis and Isenguard)
I have no other manually added addons.
11:36:09.001 T:952  NOTICE: special://profile/ is mapped to: special://masterprofile/
11:36:09.001 T:952  NOTICE: -----------------------------------------------------------------------
11:36:09.001 T:952  NOTICE: Starting Kodi (17.0-RC3 Git:20170111-4d93228-dirty). Platform: Windows NT x86 32-bit
11:36:09.001 T:952  NOTICE: Using Release Kodi x32 build
11:36:09.001 T:952  NOTICE: Kodi compiled Jan 12 2017 by MSVC 190024210 for Windows NT x86 32-bit version 6.3 (0x06030000)
11:36:09.001 T:952  NOTICE: Running on Acer AO756 with Windows 10, kernel: Windows NT x86 64-bit version 10.0
11:36:09.003 T:952  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
11:36:09.003 T:952  NOTICE: Host CPU: Unknown, 2 cores available
11:36:09.004 T:952  NOTICE: Desktop Resolution: 1366x768 32Bit at 60Hz
11:36:09.004 T:952  NOTICE: Running with administrator rights
11:36:09.007 T:952  NOTICE: Aero is enabled
11:36:09.007 T:952  NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\Kodi
11:36:09.007 T:952  NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\Kodi
11:36:09.007 T:952  NOTICE: special://xbmcbinaddons/ is mapped to: C:\Program Files (x86)\Kodi/addons
11:36:09.007 T:952  NOTICE: special://masterprofile/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\userdata
11:36:09.007 T:952  NOTICE: special://home/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\
11:36:09.007 T:952  NOTICE: special://temp/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\cache
11:36:09.007 T:952  NOTICE: special://logpath/ is mapped to: C:\Users\Media\AppData\Roaming\Kodi\
11:36:09.007 T:952  NOTICE: The executable running is: C:\Program Files (x86)\Kodi\Kodi.exe
11:36:09.048 T:952  NOTICE: Local hostname: Media
11:36:09.048 T:952  NOTICE: Log File is located: C:\Users\Media\AppData\Roaming\Kodi\/kodi.log
11:36:09.048 T:952  NOTICE: -----------------------------------------------------------------------
11:36:09.066 T:952  NOTICE: load settings...
11:36:09.087 T:952 WARNING: CSettingString: unknown options filler "timezonecountries" of "locale.timezonecountry"
11:36:09.087 T:952 WARNING: CSettingString: unknown options filler "timezones" of "locale.timezone"
11:36:09.092 T:952   ERROR: CSettings: unable to load settings from special://masterprofile/guisettings.xml, creating new default settings
11:36:09.121 T:952  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
11:36:09.121 T:952  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
11:36:09.121 T:952  NOTICE: Default Video Player: VideoPlayer
11:36:09.121 T:952  NOTICE: Default Audio Player: paplayer
11:36:09.121 T:952  NOTICE: Disabled debug logging due to GUI setting. Level 0.
11:36:09.121 T:952  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
11:36:09.121 T:952  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
11:36:09.122 T:952  NOTICE: Loaded playercorefactory configuration
11:36:09.122 T:952  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
11:36:09.122 T:952  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
11:36:09.541 T:952  NOTICE: ADDONS: Using repository repository.xbmc.org
11:36:09.588 T:1164  NOTICE: Found 2 Lists of Devices
11:36:09.588 T:1164  NOTICE: Enumerated DIRECTSOUND devices:
11:36:09.588 T:1164  NOTICE:     Device 1
11:36:09.588 T:1164  NOTICE:         m_deviceName      : {70E12A80-BB7B-487E-9349-13909A08AA81}
11:36:09.588 T:1164  NOTICE:         m_displayName     : Speakers - Speakers (2- High Definition Audio Device)
11:36:09.588 T:1164  NOTICE:         m_displayNameExtra: DIRECTSOUND: Speakers (2- High Definition Audio Device)
11:36:09.588 T:1164  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
11:36:09.588 T:1164  NOTICE:         m_channels        : FL,FR
11:36:09.588 T:1164  NOTICE:         m_sampleRates     : 44100
11:36:09.588 T:1164  NOTICE:         m_dataFormats     : AE_FMT_FLOAT
11:36:09.588 T:1164  NOTICE:         m_streamTypes     : No passthrough capabilities
11:36:09.588 T:1164  NOTICE:     Device 2
11:36:09.588 T:1164  NOTICE:         m_deviceName      : default
11:36:09.589 T:1164  NOTICE:         m_displayName     : default
11:36:09.589 T:1164  NOTICE:         m_displayNameExtra:
11:36:09.589 T:1164  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
11:36:09.589 T:1164  NOTICE:         m_channels        : FL,FR
11:36:09.589 T:1164  NOTICE:         m_sampleRates     : 44100
11:36:09.589 T:1164  NOTICE:         m_dataFormats     : AE_FMT_FLOAT
11:36:09.589 T:1164  NOTICE:         m_streamTypes     : No passthrough capabilities
11:36:09.589 T:1164  NOTICE: Enumerated WASAPI devices:
11:36:09.589 T:1164  NOTICE:     Device 1
11:36:09.589 T:1164  NOTICE:         m_deviceName      : {70E12A80-BB7B-487E-9349-13909A08AA81}
11:36:09.589 T:1164  NOTICE:         m_displayName     : Speakers - Speakers (2- High Definition Audio Device)
11:36:09.589 T:1164  NOTICE:         m_displayNameExtra: WASAPI: Speakers (2- High Definition Audio Device)
11:36:09.589 T:1164  NOTICE:         m_sampleRates     : 192000,96000,48000,44100
11:36:09.589 T:1164  NOTICE:         m_dataFormats     : AE_FMT_S24NE4MSB,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
11:36:09.589 T:1164  NOTICE:     Device 2
11:36:09.589 T:1164  NOTICE:         m_deviceName      : default
11:36:09.641 T:952  NOTICE: Found screen: Generic PnP Monitor on Intel(R) HD Graphics, adapter 0.
11:36:09.642 T:952  NOTICE: Primary mode: 1366x768@ 60.00 - Full Screen
11:36:09.643 T:952  NOTICE: Additional mode: 320x200@ 60.00 - Full Screen
11:36:09.643 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.643 T:952  NOTICE: Additional mode: 320x240@ 60.00 - Full Screen
11:36:09.644 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.644 T:952  NOTICE: Additional mode: 400x300@ 60.00 - Full Screen
11:36:09.645 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.645 T:952  NOTICE: Additional mode: 512x384@ 60.00 - Full Screen
11:36:09.646 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.646 T:952  NOTICE: Additional mode: 640x400@ 60.00 - Full Screen
11:36:09.646 T:952  NOTICE: Additional mode: 640x480@ 60.00 - Full Screen
11:36:09.647 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.647 T:952  NOTICE: Additional mode: 800x600@ 60.00 - Full Screen
11:36:09.648 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.648 T:952  NOTICE: Additional mode: 1024x768@ 60.00 - Full Screen
11:36:09.649 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.649 T:952  NOTICE: Additional mode: 1280x600@ 60.00 - Full Screen
11:36:09.649 T:952  NOTICE: Additional mode: 1280x720@ 60.00 - Full Screen
11:36:09.650 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.650 T:952  NOTICE: Additional mode: 1280x768@ 60.00 - Full Screen
11:36:09.651 T:952  NOTICE: Previous line repeats 2 times.
11:36:09.651 T:952  NOTICE: Additional mode: 1360x768@ 60.00 - Full Screen
11:36:09.651 T:952  NOTICE: Additional mode: 1366x768@ 60.00 - Full Screen
11:36:09.652 T:952  NOTICE: Checking resolution 16
11:36:10.231 T:1708  NOTICE: Running database version Addons26
11:36:11.992 T:952 WARNING: CSkinInfo: failed to load skin settings
11:36:12.248 T:952 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
11:36:12.429 T:952  NOTICE: initialize done
11:36:12.429 T:952  NOTICE: Running the application...
11:36:12.431 T:952  NOTICE: starting upnp client
11:36:12.492 T:3480  NOTICE: ES: Starting UDP Event server on port 9777
11:36:12.492 T:3480  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
11:36:18.502 T:6396   ERROR: XFILE::CDirectory::GetDirectory - Error getting addons://all/
11:36:20.103 T:5988   ERROR: XFILE::CDirectory::GetDirectory - Error getting
11:36:23.152 T:952   ERROR: Previous line repeats 6 times.
11:36:23.153 T:952   ERROR: XFILE::CDirectory::GetDirectory - Error getting addons://sources/
11:36:23.153 T:952   ERROR: CGUIMediaWindow::GetDirectory(addons://sources/) failed
11:36:31.748 T:6396   ERROR: XFILE::CDirectory::GetDirectory - Error getting
11:37:28.910 T:952   ERROR: Previous line repeats 2 times.
11:37:28.910 T:952   ERROR: Control 55 in window 10025 has been asked to focus, but it can't
11:37:33.163 T:6768  NOTICE: [xbmcswift2] Request for "/" matches rule for function "showMain"
11:37:35.071 T:4428  NOTICE: [xbmcswift2] Request for "/all/" matches rule for function "showAllShows"
11:37:36.734 T:4428  NOTICE: [plugin.video.geekandsundry] Using: html.parser
11:44:52.942 T:6676  NOTICE: Previous line repeats 38 times.
11:44:52.942 T:6676  NOTICE: [xbmcswift2] Request for "/show/http%3A%2F%2Fgeekandsundry.com%2Fshows%2Flarps%2F" matches rule for function "showShow"
11:44:53.660 T:6676  NOTICE: [plugin.video.geekandsundry] Using: html.parser
11:45:01.947 T:6224  NOTICE: Previous line repeats 1 times.
11:45:01.947 T:6224  NOTICE: [xbmcswift2] Request for "/play_url/http%3A%2F%2Fgeekandsundry.com%2Flarps-the-series-coming-to-geek-sundry-january-16%2F" matches rule for function "showVideoURL"
11:45:05.527 T:6224  NOTICE: [plugin.video.geekandsundry] Using: html.parser
11:45:07.889 T:6516 WARNING: [plugin.video.youtube] Switching API key set from  to 1
11:45:08.467 T:6516  NOTICE: [plugin.video.youtube] Running: YouTube (5.3.6) on Krypton (17.0) with Python 2.7.11
11:45:09.593 T:1932  NOTICE: Previous line repeats 1 times.
11:45:09.593 T:1932  NOTICE: [xbmcswift2] Request for "/show/http%3A%2F%2Fgeekandsundry.com%2Fshows%2Flarps%2F" matches rule for function "showShow"
11:45:27.106 T:952  NOTICE: VideoPlayer: Opening: https://r6---sn-uxa0n-t35l.googlevideo.com/videoplayback?upn=fjhdwIm9lG8&mime=video/mp4&sparams=dur,ei,id,initcwndbps,ip,ipbits,itag,lmt,mime,mm,mn,ms,mv,pl,ratebypass,requiressl,source,upn,expire&id=o-ACS7_93Sdjb-x-hHlnDjs2YGKsx6JDOL8K8q9XU-uI2D&itag=22&key=yt6&ip=75.157.157.108&dur=50.689&lmt=1472172445646447&ei=VBeBWPvUI8_c-wOf1p6QCg&ms=au&mt=1484854854&mv=m&expire=1484876724&requiressl=yes&ipbits=0&mm=31&mn=sn-uxa0n-t35l&source=youtube&initcwndbps=2183750&ratebypass=yes&signature=AC004782E2BC0273ABC1690949ED558A04214D11.AC90DF044E28BAC257D592F3C0923C28216552D5&pl=22
11:45:27.106 T:952 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
11:45:27.206 T:952   ERROR: DXVA::CProcessorHD::IsFormatSupported: Unsupported format 104 for 1.
11:45:27.206 T:952   ERROR: DXVA::CProcessorHD::IsFormatSupported: Unsupported format 105 for 1.
11:45:27.207 T:5712  NOTICE: Creating InputStream
11:45:28.171 T:5712  NOTICE: Creating Demuxer
11:45:28.239 T:5712  NOTICE: Opening stream: 0 source: 256
11:45:28.239 T:5712  NOTICE: Creating video codec with codec id: 28
11:45:28.239 T:5712  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
11:45:28.240 T:5712  NOTICE: Creating video thread
11:45:28.240 T:5712  NOTICE: Opening stream: 1 source: 256
11:45:28.240 T:5712  NOTICE: Finding audio codec for: 86018
11:45:28.242 T:5712  NOTICE: Creating audio thread
11:45:28.242 T:6504  NOTICE: running thread: video_thread
11:45:28.243 T:2344  NOTICE: running thread: CVideoPlayerAudio::Process()
11:45:28.246 T:6504  NOTICE: CDVDVideoCodecFFmpeg::GetFormat - Creating DXVA(1280x720)
11:45:28.254 T:2344  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
11:45:28.453 T:952  NOTICE: D3D: rendering method forced to DXVA processor
11:45:28.453 T:952  NOTICE: DXVA::CProcessorHD::InitProcessor: Supported deinterlace methods: Blend:yes, Bob:yes, Adaptive:yes, MoComp:yes.
11:45:28.466 T:952 WARNING: CWinRenderer::UpdateVideoFilter - chosen scaling method 1 is not supported by renderer
11:45:28.781 T:6504  NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41708
11:46:18.826 T:2344  NOTICE: CVideoPlayerAudio::Process - stream stalled
11:46:18.881 T:5712  NOTICE: CVideoPlayer::OnExit()
11:46:18.881 T:5712  NOTICE: VideoPlayer: eof, waiting for queues to empty
11:46:18.881 T:5712  NOTICE: Closing stream player 1
11:46:18.881 T:5712  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
11:46:18.881 T:5712  NOTICE: Waiting for audio thread to exit
11:46:18.881 T:2344   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
11:46:18.881 T:2344  NOTICE: thread end: CVideoPlayerAudio::OnExit()
11:46:18.882 T:5712  NOTICE: Closing audio device
11:46:18.882 T:5712  NOTICE: Deleting audio codec
11:46:18.882 T:5712  NOTICE: Closing stream player 2
11:46:18.882 T:5712  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
11:46:18.925 T:5712  NOTICE: waiting for video thread to exit
11:46:18.925 T:6504   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
11:46:18.926 T:6504  NOTICE: thread end: video_thread
11:46:18.926 T:5712  NOTICE: deleting video codec
11:46:18.998 T:5712  NOTICE: DXVA::CDecoder::Close - closing decoder
11:46:18.998 T:5712  NOTICE: DXVA::Close - closing decoder context
11:46:19.044 T:952   ERROR: Control 55 in window 10025 has been asked to focus, but it can't
11:46:19.223 T:952  NOTICE: CVideoPlayer::CloseFile()
11:46:19.223 T:952  NOTICE: VideoPlayer: waiting for threads to exit
11:46:19.224 T:952  NOTICE: VideoPlayer: finished waiting
11:46:19.225 T:952  NOTICE: CVideoPlayer::CloseFile()
11:46:19.225 T:952  NOTICE: VideoPlayer: waiting for threads to exit
11:46:19.225 T:952  NOTICE: VideoPlayer: finished waiting
11:46:19.851 T:4644  NOTICE: [xbmcswift2] Request for "/show/http%3A%2F%2Fgeekandsundry.com%2Fshows%2Flarps%2F" matches rule for function "showShow"
11:46:24.724 T:6408  NOTICE: [xbmcswift2] Request for "/play_url/http%3A%2F%2Fgeekandsundry.com%2Flarps-the-series-episode-0-larps%2F" matches rule for function "showVideoURL"
11:46:29.422 T:6408  NOTICE: [plugin.video.geekandsundry] Using: html.parser
11:46:29.438 T:6408   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.AttributeError'>
                                            Error Contents: 'NoneType' object has no attribute 'group'
                                              File "C:\Users\Media\AppData\Roaming\Kodi\addons\plugin.video.geekandsundry\geekandsundry.py", line 382, in <module>
                                                plugin.run()
                                              File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 332, in run
                                                items = self._dispatch(self.request.path)
                                              File "C:\Users\Media\AppData\Roaming\Kodi\addons\script.module.xbmcswift2\lib\xbmcswift2\plugin.py", line 306, in _dispatch
                                                listitems = view_func(**items)
                                              File "C:\Users\Media\AppData\Roaming\Kodi\addons\plugin.video.geekandsundry\geekandsundry.py", line 259, in showVideoURL
                                                ID = re.search('href="http://youtu.be/(?P<id>[^"]+)"',html).group(1)
                                            AttributeError: 'NoneType' object has no attribute 'group'
11:46:29.492 T:952   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.geekandsundry/play_url/http%3A%2F%2Fgeekandsundry.com%2Flarps-the-series-episode-0-larps%2F]
Ditto here too. Some Tabletop episodes won't play but the interviews do and most of the gagreels do. I suspect it is a site scraping issue.
16:34:39.811 T:1236268016  NOTICE: [xbmcswift2] Request for "/" matches rule for function "showMain"
16:34:49.785 T:1192952816  NOTICE: [xbmcswift2] Request for "/all/" matches rule for function "showAllShows"
16:34:50.759 T:1192952816  NOTICE: [plugin.video.geekandsundry] Using: html.parser
16:35:13.561 T:1236268016  NOTICE: Previous line repeats 7 times.
16:35:13.561 T:1236268016  NOTICE: [xbmcswift2] Request for "/show/http%3A%2F%2Fgeekandsundry.com%2Fshows%2Ftabletop%2F" matches rule for function "showShow"
16:35:14.292 T:1236268016  NOTICE: [plugin.video.geekandsundry] Using: html.parser
16:36:20.156 T:1725953008  NOTICE: Previous line repeats 11 times.
16:36:20.156 T:1725953008  NOTICE: EMBY.kodimonitor -> Method: Playlist.OnClear Data: {"playlistid":1}
16:36:23.441 T:1184564208  NOTICE: [xbmcswift2] Request for "/play_url/http%3A%2F%2Fgeekandsundry.com%2Fking-of-tokyo-totalbiscuit-greg-zeschuk-craig-benzine-and-wil-wheaton-on-ta%2F" matches rule for function "showVideoURL"
16:36:25.639 T:1184564208  NOTICE: [plugin.video.geekandsundry] Using: html.parser
16:36:25.697 T:1184564208   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                              File "/home/osmc/.kodi/addons/plugin.video.geekandsundry/geekandsundry.py", line 382, in <module>
                                                plugin.run()
                                              File "/home/osmc/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 332, in run
                                              File "/home/osmc/.kodi/addons/script.module.xbmcswift2/lib/xbmcswift2/plugin.py", line 306, in _dispatch
                                              File "/home/osmc/.kodi/addons/plugin.video.geekandsundry/geekandsundry.py", line 259, in showVideoURL
16:36:26.063 T:1958896560   ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.geekandsundry/play_url/http%3A%2F%2Fgeekandsundry.com%2Fking-of-tokyo-totalbiscuit-greg-zeschuk-craig-benzine-and-wil-wheaton-on-ta%2F]
Oh and here is it when it works:
16:40:35.108 T:1301279728  NOTICE: [xbmcswift2] Request for "/play_url/http%3A%2F%2Fgeekandsundry.com%2Fgreg-zeschuk-extended-interview-king-of-tokyo-tabletop-se2ep4%2F" matches rule for function "showVideoURL"
16:40:37.316 T:1301279728  NOTICE: [plugin.video.geekandsundry] Using: html.parser
16:40:39.514 T:1315959792  NOTICE: [plugin.video.youtube] Running: YouTube (5.3.10) on Krypton (Kodi-17.1) with Python 2.7.9
16:40:42.787 T:1958896560  NOTICE: VideoPlayer: Opening: https://r3---sn-aigllnz7.googlevideo.com/videoplayback?beids=[9452306]&id=o-AMnP-cjQf6cMpQDzRnW_QCQssYueEBsHaHw1NnX0NSev&itag=22&dur=143.243&lmt=1387057223095337&key=yt6&ip=81.132.32.235&expire=1488667241&ei=Ce66WN3vJIuVWuK7hdgM&ms=au&mt=1488645267&mv=m&ipbits=0&mm=31&mn=sn-aigllnz7&requiressl=yes&ratebypass=yes&source=youtube&pl=15&initcwndbps=1306250&sparams=dur,ei,id,initcwndbps,ip,ipbits,itag,lmt,mime,mm,mn,ms,mv,pl,ratebypass,requiressl,source,upn,expire&upn=xL8vdQ6me20&mime=video/mp4&signature=D79CFB813728A3D09C0A4266B32299506487DA30.42AAA5452259950EE5E65A6F0E6971BF1C7C55D3
16:40:42.787 T:1958896560 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
16:40:42.860 T:1223681008  NOTICE: Creating InputStream
16:40:43.781 T:1223681008  NOTICE: Creating Demuxer
16:40:44.300 T:1223681008  NOTICE: Opening stream: 0 source: 256
16:40:44.301 T:1223681008  NOTICE: Creating video codec with codec id: 28
16:40:44.317 T:1223681008  NOTICE: Creating video thread
16:40:44.318 T:1174074352  NOTICE: running thread: video_thread
16:40:44.318 T:1223681008  NOTICE: Opening stream: 1 source: 256
16:40:44.318 T:1223681008  NOTICE: Finding audio codec for: 86018
16:40:44.323 T:1223681008  NOTICE: Creating audio thread
16:40:44.324 T:1159721968  NOTICE: running thread: CVideoPlayerAudio::Process()
16:40:44.342 T:1159721968  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
