Full Version: flashing music widget
In the Music section, I added the widget "Recently added albums"
Navigating back home, move on the Music, there is some info in the widget are, but
- some icons/art are flashing without actual pics of the artist
- some other have NAS access to show the fanart image... shouldn't this be Thumbnail cache access?
- navigiation to those widget blocks, do not show a blue border... so navigation is very strange
are there more peopl experiencing this problem?
Using Kodi 17 RC3, mimic 5.0.2 running WIn10
Can you post a screenshot? Sounds like your artwork cache may be messed up, or you need to specify different art in the widget settings. Make sure it is set to Thumbnail.
- I had too many problems after upgrading Kodi 16 to 17rc3
- there fore I decided to delete Kodi folders in [Program files] and in [AppData\Roaming]
- full install of 17rc3 and reconfigure all options
- after scanning music library, the widget works OK, without flashing
so problem solved
