I've identified 5 movies (3 - Little Einsteins and 2 - Mother Goose Club ripped from DVD for my daughter) using Missing Movie Scanner. The Little Einsteins were identified using Filebot but Mother Goose Club was not identified. Neither are being displayed in the Library so my wife/daughter do not realize they are available. Kodi plays them as expected if you browse the directories within the File section. What other apps should I use to properly rename the files for Kodi?
The simplest way is to access whichever database the scraper you are using is linked to (by default it is
www.thetvdb.com for TV shows), look up the show in question there and then rename your files to match.
The mother goose club can be found
here , although it only seems to have 5 episodes?
These are DVD not TV shows.
If they are not DVDs of TV shows then you'd need to set up your own
NFO (wiki) files for them as there will be no metadata in the database to be used. That is presuming you're DVDs don't feature tv shows from the link I gave before.
I created a new TV_SHOWS directory and tried a few different scapers but they aren't found. They are not in the "Movies" section even though a directory exists but they do show up in the Movies/Videos's file section. No posters though.
They're not showing as they aren't in the scraper database. You'd need to either make your own
NFO (wiki) files for them or alternatively get an account on the scraper database site and add them for everyone.
