2017-01-24, 07:38
I run kodi off a sql backend, and tonight I was migrating it to another box and noticed a few things.
I've been running kodi back when it was called xbmc.. and currently on v17rc3.
On that box I exported a .sql file and went to import it into a new fresh v17rc3 instance (ran once to create the folders/schema) -- so yes same versions on both boxes.
First issue, was unable to import .sql:
Looking at logs to see what kodi created,
Yep no Crop* columns.. so they were removed at some point but no migration/alter of the existing user schema happened...
Tracked it down to: https://github.com/xbmc/xbmc/commit/d30e...ccdb3d2d62
Easy fix, run this to fix old database to conform to existing schema:
Okay, now that I have the data in the database I noticed a lot of old stuff that shouldn't be in there..
When removing a tvshow from kodi the tables `path`, `tvshow`, and `files` never get their data removed.
Running clean library removes the episodes but the references to files never get cleaned up properly... so you end up with tables pointing to invalid and orphaned information in the db.
There is a trigger when deleting a show.. but it doesnt cleanup everything...
`delete_tvshow` trigger:
To view stale tvshow paths:
From this list, plug in the idPath that you get back for one of the shows inplace of ### below:
tvshow:
now the delete_tvshow trigger *should* have deleted all the actor_link info but you can see some still exists:
actor_link:
now, you cant clean up the stale files in the db because the relationship info in the episode table is missing (### is the show id from above):
assume it's gone because of clean library...
there are also blank filenames in the db which looks like a sign of bad cleanup:
* removed `myvideos107` from the sql statements to make it easier for others to copy and paste since this problem isnt only found in v17
SQL Error (1054): Unknown column 'Crop' in 'field list'
18:52:56.139 T:4476 DEBUG: Mysql execute: CREATE TABLE settings ( idFile integer, Deinterlace bool,ViewMode integer,ZoomAmount float, PixelRatio float, VerticalShift float, AudioStream integer, SubtitleStream integer,SubtitleDelay float, SubtitlesOn bool, Brightness float, Contrast float, Gamma float,VolumeAmplification float, AudioDelay float, OutputToAllSpeakers bool, ResumeTime integer,Sharpness float, NoiseReduction float, NonLinStretch bool, PostProcess bool,ScalingMethod integer, DeinterlaceMode integer, StereoMode integer, StereoInvert bool, VideoStream integer)
ALTER TABLE `settings` DROP COLUMN `Crop`, DROP COLUMN `CropLeft`, DROP COLUMN `CropRight`, DROP COLUMN `CropTop`, DROP COLUMN `CropBottom`;
BEGIN DELETE FROM actor_link WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM director_link WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM studio_link WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM tvshowlinkpath WHERE idShow=old.idShow; DELETE FROM genre_link WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM movielinktvshow WHERE idShow=old.idShow; DELETE FROM seasons WHERE idShow=old.idShow; DELETE FROM art WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM tag_link WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM rating WHERE media_id=old.idShow AND media_type='tvshow'; DELETE FROM uniqueid WHERE media_id=old.idShow AND media_type='tvshow'; END
SELECT * FROM `path` WHERE (`strHash` IS NULL OR `strHash` = '') AND `idParentPath` = 3 ORDER BY `strHash` ASC;
tvshow:
SELECT * FROM `tvshow` WHERE idShow = (SELECT idShow FROM `tvshowlinkpath` WHERE idPath = ###);
actor_link:
SELECT * FROM `actor_link` WHERE media_type = 'tvshow' AND media_id = (SELECT idShow FROM `tvshowlinkpath` WHERE idPath = ###);
SELECT * FROM `episode` WHERE `idShow` = ###;
SELECT * FROM `files` WHERE `strFilename` = '' ORDER BY `idPath` ASC;
