2017-01-24, 16:25
I have a problem installing Kodi 17 RC 3 on an Android TV Box (S82 from Tronsmart).
I believe it runs Android 4.4.2 and like usual for many Android TV boxes updates are not available.
I turned off file verification and allowed unknown sources to install. The Kodi version 16.1 runs just fine, but regardless how often I download version R3 from the KODI page I get a parse error. I also tried the site apkmirror and got the same problem, which means it has something to do with my installed Android or Box itself.
The last step that was mentioned in the YouTube help files was resetting the device completely, but I doubt this will solve the problem if all other tips did not work.
Any ideas how I can fix that issue?
Thanks,
Thorsten
Thanks,
Thorsten
