Hey all.
I am having trouble installing KODI- 17.0- Krypton_rc3-x86_64.dmg on my mac.
i get a warning message: The following file can not be opened.
system following:
macOS Sierra
Version 10.12.1
MacBook Pro (15-inch, Mid 2012)
Processor 2.3 GHz Intel Core i7
Memory 4 GB 1600 MHz DDR3
Graphics Intel HD Graphics 4000 1536 MB
What other information do you need.
Any help will be great.
The exact message you get is needed
KODI- 17.0- Krypton_rc3-x86_64.dmg Image not recognized
So you can't even open the dmg file and see the blue folder with the kodi app in it? If so - try to redownload the dmg.
I have downloaded a number of times with the same result. Do you have a link from a different source i can try.
Can you answer my question first? Still unsure at which exact stage it fails for you...
yes that is correct. i can't even open the dmg file and see the blue folder with the kodi app in it.
Just downloaded kodi-17.0-Krypton_rc4-x86_64.dmg and had no issues opening the .dmg (macOS 10.11.6)
(2017-01-30, 19:18)CouchPie Wrote: [ -> ]Just downloaded kodi-17.0-Krypton_rc4-x86_64.dmg and had no issues opening the .dmg (macOS 10.11.6)
Hello CouchPie, i just downloaded the .dmg and i am having the same trouble. it says image not recognised.
Hi caleb14: This is very unusual. Try the following:
1. Goto Finder and select the .dmg.
2. Hit Command+i to get details.
3. Check that the dmg has exactly 76.962.200 Bytes
If this is okay, you may verify the md5 hash:
1. Open Terminal and type md5
2. Drag the dmg onto the Terminal window and hit Return
3. Check that it spits out 566a847e82922b7624b437358dc2d61c
If both are OK, you may try to mount the .dmg via Disk Utility.
Thank you for the info CouchPie
i have checked the file and it is only 3,260,617 bytes
i downloaded this file from
https://kodi.tv/download/
i downloaded both Mac OS X
Release build: 64bit
Nightly build: 64bit
and get the same result.
Do you have a link where i can DL from.
Thank you. it worked. finally ^^
can i use this same file for apple tv.
what add ons do i need to put on my computer for kodi now i have it running. thank you
