Full Version: JAVA Error
Pages: 1 2
I don't know if this has been answered. I can't find the right thread. I'm getting this JAVA error. Tried clearing the cache and reinstalling Java and tinymeida:
hmm... what Java version do you currently have installed?
and on what OS? Windows 10?
What was the last time it worked?
Can you upload the tmm.log from /logs/ directory?
PS: you are the 3rd today who has exact this issue :|
Did you upgrade Java recently? (or did it itself with autoupdater?)
made an account just for this. Having the same error. Seems since the latest Java 8 update something went screwy (update happened today)
tmm.log from mine
2017-01-25 21:34:18,338 DEBUG [main] org.tinymediamanager.core.Settings:242 - Loading settings from data
2017-01-25 21:34:18,570 INFO [main] org.tinymediamanager.TinyMediaManager:150 - =====================================================
2017-01-25 21:34:18,570 INFO [main] org.tinymediamanager.TinyMediaManager:151 - === tinyMediaManager © 2012-2016 Manuel Laggner ===
2017-01-25 21:34:18,570 INFO [main] org.tinymediamanager.TinyMediaManager:152 - =====================================================
2017-01-25 21:34:18,571 INFO [main] org.tinymediamanager.TinyMediaManager:153 - tmm.version : 2.9.1
2017-01-25 21:34:18,571 INFO [main] org.tinymediamanager.TinyMediaManager:159 - os.name : Windows 10
2017-01-25 21:34:18,571 INFO [main] org.tinymediamanager.TinyMediaManager:160 - os.version : 10.0
2017-01-25 21:34:18,571 INFO [main] org.tinymediamanager.TinyMediaManager:161 - os.arch : amd64
2017-01-25 21:34:18,577 INFO [main] org.tinymediamanager.TinyMediaManager:163 - java.version : 1.8.0_121
2017-01-25 21:34:18,577 INFO [main] org.tinymediamanager.TinyMediaManager:530 - default encoding : UTF-8 | UTF8 | UTF-8
2017-01-25 21:34:18,577 INFO [main] org.tinymediamanager.TinyMediaManager:530 - set encoding to : UTF-8 | UTF8 | UTF-8
2017-01-25 21:34:18,577 INFO [main] org.tinymediamanager.TinyMediaManager:192 - System language : nl_NL
2017-01-25 21:34:18,577 INFO [main] org.tinymediamanager.TinyMediaManager:193 - GUI language : en_US
2017-01-25 21:34:18,579 INFO [main] org.tinymediamanager.TinyMediaManager:194 - Scraper language : English
2017-01-25 21:34:18,579 INFO [main] org.tinymediamanager.TinyMediaManager:195 - TV Scraper lang : English
2017-01-25 21:34:18,678 INFO [main] org.tinymediamanager.TinyMediaManager:223 - =====================================================
That can't be a coincidence!
You might want to uninstal Java, and try an older version from here:
http://www.oracle.com/technetwork/java/j...12-oth-JPR
Investigating....
also made an account just for this. having the same error. here is my log; hope this can be fixed soon as it is an awesome program
2017-01-25 23:26:41,748 DEBUG [main] org.tinymediamanager.core.Settings:242 - Loading settings from data
2017-01-25 23:26:42,003 INFO [main] org.tinymediamanager.TinyMediaManager:150 - =====================================================
2017-01-25 23:26:42,003 INFO [main] org.tinymediamanager.TinyMediaManager:151 - === tinyMediaManager © 2012-2016 Manuel Laggner ===
2017-01-25 23:26:42,003 INFO [main] org.tinymediamanager.TinyMediaManager:152 - =====================================================
2017-01-25 23:26:42,004 INFO [main] org.tinymediamanager.TinyMediaManager:153 - tmm.version : 2.9.1
2017-01-25 23:26:42,004 INFO [main] org.tinymediamanager.TinyMediaManager:159 - os.name : Windows 10
2017-01-25 23:26:42,004 INFO [main] org.tinymediamanager.TinyMediaManager:160 - os.version : 10.0
2017-01-25 23:26:42,004 INFO [main] org.tinymediamanager.TinyMediaManager:161 - os.arch : x86
2017-01-25 23:26:42,009 INFO [main] org.tinymediamanager.TinyMediaManager:163 - java.version : 1.8.0_121
2017-01-25 23:26:42,009 INFO [main] org.tinymediamanager.TinyMediaManager:530 - default encoding : UTF-8 | UTF8 | UTF-8
2017-01-25 23:26:42,009 INFO [main] org.tinymediamanager.TinyMediaManager:530 - set encoding to : UTF-8 | UTF8 | UTF-8
2017-01-25 23:26:42,010 INFO [main] org.tinymediamanager.TinyMediaManager:192 - System language : en_US
2017-01-25 23:26:42,010 INFO [main] org.tinymediamanager.TinyMediaManager:193 - GUI language : en_US
2017-01-25 23:26:42,011 INFO [main] org.tinymediamanager.TinyMediaManager:194 - Scraper language : English
2017-01-25 23:26:42,011 INFO [main] org.tinymediamanager.TinyMediaManager:195 - TV Scraper lang : English
2017-01-25 23:26:42,082 INFO [main] org.tinymediamanager.TinyMediaManager:223 - =====================================================
Guys,
Which version of JAVA you would recommend?
Same error here even after installing this java version: http://www.oracle.com/technetwork/java/j...12-oth-JPR
worked fine last night, windows 10
CMD works fine, but full version and updater crash
Howdy
Installed the earliest Java x86 version
jre-8-windows-i586.exe - worked
then
jre-8u112-windows-i586.exe - worked
When i tried two versions of Java installed
Java 8 112 (x86) and Java 8 121 (x64)
TMM failed
uninstalled Java 8 121 (x64)
TMM loaded
Only jre-8u121-windows-i586.exe - worked
I couldn't get TMM working (Win7) while a x64 version of Java 8 was installed
I had the same problem.
I resolved it with the wiki, by creating "extra.txt" and ad "-Dsun.java2d.d3d=false" in it.
https://github.com/tinyMediaManager/tiny...r/wiki/FAQ
UI glitches with a remote desktop connection
If you use tinyMediaManager with a remote desktop connection software like RDP or VNC, Java can produce some weird glitches due a lack of 3D rendering with remote desktop connections.
In this case, try to create (or edit if it already exists) a file called extra.txt in the tinyMediaManager install directory and add the following line
and restart tinyMediaManager
I know this is not the same problem but it works with this mofification.
Maybe the beginning of a solution
on the minecraft forums there is a similar problem which suspects a problem with the latest java/NVIDIA version.
by setting
into extra.txt you disable d3d drawing from java (which is done by the NVIDIA driver for NVIDIA users).
That may be a clue
I couldn't reproduce that issue on the only windows machine I can use
I just got the confirmation by email:
Quote:Before I saw this email, I looked at the crash dump files I sent you and saw that nvscpapi64.dll was crashing when I launched tinyMediaManager. This is an Nvidia file, and my Nvidia drivers were updated yesterday (to version 378.49), shortly before I tried to launch TMM. I uninstalled the 3D Vision drivers, which this file is associated with, and TMM worked perfectly fine. When I re-installed the 3D Vision drivers, it stopped working again.
Adding
to the file extra.txt did work for this user too.
I had the exact same issue tonight, tried upgrading Java to latest version 8 121, but was still crashing.
The fix above worked perfectly. Thanks!
could anyone with this issue try if the updater is loading? (tinyMediaManagerUpd.exe)
Can someony please test our nightly build, if it works out-of-the-box?
http://www.tinymediamanager.org/download/nightly-build
It is now fixed!
Pages: 1 2
