Full Version: Kodi 17 - rc3/rc4: problem in slideshow: playback of videos is stumbling
Pages: 1 2 3 4 5
=12ptInfo for Upload to Kodi Forum Regarding Video Not Playing in Picture Slideshow =12ptTo Moderator: I have posted this to this sub-forum since it addresses my problem exactly. I have also posted same in the Android sub-forum as was suggested in one of the posts. Sorry for long post. I thought detailed description would be helpful along with logfile.=12ptI use Kodi to view photos and home videos on our large screen TV. I like to use slideshow mode because it offers Ken Burns style pan and zoom on images. Also, you can sort files by file date or date taken, a feature which I have not seen on other android photo/video viewer apps. This feature displays the videos in a timeline with photos in consecutive order, as opposed to watching all photos and then all videos as you would have if sorted in filename order.=12ptIn Kodi 16.1 Jarvis, the Picture slideshow viewer works flawlessly, but with 17.6 Krypton it no longer worked and every version since has had the same problem (see symptoms below). This issue has been around since January, 2017 and it would be great to have a solution. I believe there would be many Kodi users who would appreciate being able to properly use the built-in picture slideshow feature, as it was implemented in Kodi Jarvis.=12ptHardware and Software:=12ptNvidia Shield TV 16 GB and kodi-20190116-6733f379-master-arm64-v8a.apk nightly build. From Debug file, is Kodi (18.0-RC5 Git:20190116-6733f37). Platform: Android ARM 64-bit. I installed the latest nightly build hoping this issue might have been resolved and wanted to use latest build for logfile. But same issue appears in this latest build as in 17.6 Krypton.=12ptSymptoms:=12ptBefore initiate slideshow:=12ptIf just click on video file in Widelist, it plays fine. However, if view an image file first and then, with image still on screen, press right arrow on keyboard (or click Right button on controller it tries to play the next file (a video) but Video does not display, just a black screen, but audio is working. File plays to end and then repeats in endless loop. You can actually view video if click Options on left and click the “Expand” button (to right of “Next File” button) but then have exited play function and at end of video it goes back to Widelist to display the file list.=12ptAfter initiate slideshow:=12ptImages display fine and advance to next file automatically, but if next file is a video, get audio only. When video finishes, it advances to next file. If image, displays fine. If video, get audio only.=12ptNotes about logfile: HTTPS://paste.kodi.tv/foyakirafi=12ptThe first video attempted to play at Line 178 16:28:30.835 T:13793 and is file name MVI_2409.MP4. There was one image displayed in slideshow before it advanced to that video. Previous image displayed fine, but next file, a video – first a play symbol in square box and then gear icon, then black screen and audio only. That video is from a Canon M50 .mp4 1920X1080P 59.94 fps. All videos displayed the Play symbol and gear icon briefly before either playing or black screen.=12ptIt then attempted to play the next file in the slideshow, a video at line 219 16:28:38.332 T:13793 MVI_2414.MP4. This had the same problem of black screen and audio only.=12ptThere were always images displayed between each of the following videos. There is no mention of the images in the logfile perhaps because they displayed error free.=12ptOther videos mentioned in the logfile:=12ptLine 264 16:28:53.091 T:13793 MVI_4190.MP4 Canon M50 1080 29.97 fps. Black screen, audio only.=12ptLine 307 16:29:22.377 T:13793 MVI_1358.AVI Canon S410 320X240 15 fps. 0.5 second lag while displays first frame, then video displays fine.=12ptLine 351 6:29:41.010 T:13793 MVI_2778.AVI Canon SD950 640X480 30 fps Short lag, shows play symbol and gear icon then displays video fine.=12ptSummary:=12ptStrange behavior. With older .avi, low fps files, videos playing fine in slideshow, might think is codec or processor issue with 1080P 29 and 59 fps not working. But, those higher res and higher fps videos play just fine if click them one at a time and they are not preceded by an image file. So clearly the processor is up to the job and the Kodi video player has the correct codec available. This problem is not just on Nvidia Shield. I have used a less expensive Android 5 volt box and encountered the same problem… works in 16.1 and not in 17.6 and later.=12ptFinally:=12ptOut of curiosity, I uninstalled the above Kodi 18 nightly build and re-installed Kodi 16.1 Jarvis. It ran the slideshow perfectly in all respects. I uploaded a second logfile for it using the exact same video and .jpg files (except that it cycled around before I could stop the slideshow. So, it has a few more videos and .jpg files). Here is that second logfile: HTTPS://paste.kodi.tv/usujinasat in case anyone wants to do a comparison.=12ptI note also this problem was posted on GitHub 14643 (GH issue)  Oct 18, 2018 but no apparent solution there yet.
Please do not copy/paste your text directly from Microsoft Word onto our forum. It is a very allergic to that.
Sorry for previous mess. I am new to posting on this forum.
Symptoms:
Summary:
Finally:
I note also this problem was posted on GitHub https://github.com/xbmc/xbmc/issues/14643  Oct 18, 2018 but no apparent solution there yet.
Hello, i have same issue with Raspberry Pi 3. Current repository for RPi Stretch offer Kodi v18 installation only. This issues still persist in code for this hardware and several linux. Video files are not visible in picture slideshow. Probably there is issue with showing layers, because file is played on background (audio is played fine), but after click "ESC" key, i see Kodi menu with played video content on background. Pictures are showed fine, but video files showing only black screen.
This issue persist from Kodi version 17.
As perfectly decribed and documented (very early by myself ;-) TWO YEARS AGO) and in January 2019 by Pixelate 61 above this reply and again mentioned by memphis above this problem still exists.
The good news is that is was fixed in Kodi 18 but only in the windows version.
The problem still exists unchanged on the Libreelec version even in the latest with Kodi 18.
With kind regards
Martin Klein
(2019-03-28, 21:28)martin.klein Wrote: [ -> ]As perfectly decribed and documented (very early by myself ;-) TWO YEARS AGO) and in January 2019 by Pixelate 61 above this reply and again mentioned by memphis above this problem still exists.
With kind regards
Martin Klein
It's a shame that nobody from the dev team has a focus on fixing this severe issue for more than 3 years now. This is why I'm still on 15.2 (on Nvidia shield), which is the latest release with a working slideshow for more than 12000 pics/vids. Even the mentioned windows release of 18.1 has severe problems with slideshow stability, not to mention that it struggles with large amounts of multimedia data.
Thanks to these articles I solved my problem  Blush ... I have been dealing with this problem for more than a month . Cool . Thanks to everyone.
(2019-06-26, 05:41)IdaHarrington Wrote: [ -> ]Thanks to these articles I solved my problem
You have now posted 3 almost identical and totally useless 'thank you' posts in different threads on this forum.
If you have no intention of participating in a more meaningful way than what you have shown so far, it's best for you to move on. In which case your account will be closed.
And should you continue in this way, the moderators can push a very effective ban button.
This is a one and final warning. The choice is yours.
Pages: 1 2 3 4 5
