hello Im an old timer and don't much know about this program.. Have been using it with help from friends. tonight I am gettinh add-on is incompatible due to unmet dependencies. would you like to disable it on your system.... then it goes through about 15 more items. cannot get out of it. Can't reboot the program. Have shut down and restarted the Mac. Your help will be welcome
We cant do magic from out here so depending on your knowledge of kodi and/or osx
A. Could you produce a kodi log
log and we can try to analyse it ?
B. or would you like to start over clean with a fresh kodi installation ?
1. move the kodi app to the trash
2. remove the kodi folder from the hidden folder userdata/application support
(While in the Finder, click on the "Go" menu and hold down ⌥ Option, then select Library)
3. Reinstall kodi from
https://kodi.tv/download/
4. and setup your kodi and library again.
