Full Version: Release 2.9.2
27.01.2017 - Version 2.9.2
+ added action: download missing artwork
+ added parsing of Synology VSMETA files
+ added shortcut (CTRL - F) to jump to the search field (thx @hampelratte)
+ improved user interaction for tags and genres (thx @hampelratte)
+ get a list of video files for TV show export with episode.videoFiles
+ added HDRip as an own media source
+ movie renamer: added $K token (first tag)
+ added moving of genres/tag in the movie editor
x fixed localized artwork loading for brazilian users
x fixed deleting of backup folder in windows #120
x fixed detection/renaming of movieset artwork in movie folders #111
x do not remove movie set artwork when removing movies from tmm #111
x do not remove movie sets when removing movies/data sources from tmm #111
x increased max memory setting for 64bit users to 2560MB
x updated MediaInfo to 0.7.91
x fixed parsing of media source
Thanks for the great work
When using the download missing art work feature I am getting "failed to get artwork for (tv show name)"
Is that an error or does that mean it did not find any artwork?
I am getting this error for 99% of my tv shows.
I am unsure
could you provide me some logs? (pastebin, pm or github issue)
(2017-01-28, 10:04)mlaggner Wrote: [ -> ]I am unsure
Sure, where is the error log saved (OSX)
Here is a pic in the mean time. Seems to be this error over and over
right click on tmm -> show package contents and look for a logs folder inside the package (dunno the exact path right now)
(2017-01-28, 18:53)mlaggner Wrote: [ -> ]right click on tmm -> show package contents and look for a logs folder inside the package (dunno the exact path right now)
Thanks, I Pm'ed you pastebin link.
Please Let me know if you need anything else.
We're the logs of any help?
sry did not have time to look at it. But it could be possible that there are simply no DL links for that artwork and I did not check against that.
You could check yourself if there is not DL aut fanart.tv for the selected shows/episodes
Just had a look at the logs and as far as I could see these errors come from "not available" artwork on the net.
We will add some checks in the next version.
