2017-01-29, 08:26
2017-01-29, 12:26
Details please
2017-01-31, 02:29
(2017-01-29, 12:26)Memphiz Wrote: [ -> ]Details please
Kodi crashes on 10.2 jailbreak
2017-01-31, 17:12
Have the same problem on 10.2 jailbreak with iPad Air.
First I tried Kodi 15 from the cydia repo. Force closes when i am starting Kodi.
What is working so far is installing Kodi 16 via Cydia Impactor. However you would have to reinstall Kodi every 7 days.
Also, installing the .deb (Kodi 16) from the wiki page with Filza does not help. Forse closes as well when starting Kodi.
2017-02-02, 06:35
The following is a crash log of Kodi 17 on an iPad Air 2 jailbroken. Anything else you would need?
{"blame":[],"app_name":"Kodi","timestamp":"2017-02-01 21:59:49.46 -0600","app_version":"","slice_uuid":"6d18973c-abfa-30ed-a7b2-22e31747ab37","adam_id":0,"build_version":"1.0","bundleID":"org.xbmc.kodi-ios","share_with_app_devs":false,"is_first_party":true,"bug_type":"109","os_version":"iPhone OS 10.2 (14C92)","incident_id":"D01D932F-5701-4ADE-AC1F-DE996F16BBD8","name":"Kodi","symbolicated":true}
Incident Identifier: D01D932F-5701-4ADE-AC1F-DE996F16BBD8
CrashReporter Key: cc14622fefe14a300cf4078e1cef42f6bbe29a83
Hardware Model: iPad5,3
Process: Kodi [4480]
Path: /Applications/Kodi.app/Kodi
Identifier: org.xbmc.kodi-ios
Version: 1.0
Code Type: ARM (Native)
Role: Foreground
Parent Process: launchd [1]
Coalition: org.xbmc.kodi-ios [1134]
Date/Time: 2017-02-01 21:59:49.2035 -0600
Launch Time: 2017-02-01 21:59:48.9770 -0600
OS Version: iPhone OS 10.2 (14C92)
Report Version: 104
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Termination Description: DYLD, Library not loaded: @executable_path/Frameworks/libsmbclient.dylib | Referenced from: /Applications/Kodi.app/Kodi | Reason: no suitable image found. Did find: | /Applications/Kodi.app/Frameworks/libsmbclient.dylib: required code signature missing for '/Applications/Kodi.app/Frameworks/libsmbclient.dylib' | | /Applications/Kodi.app/Frameworks/libsmbclient.dylib: required code signature missing for '/Applications/Kodi.app/Frameworks/libsmbclient.dylib' |
Triggered by Thread: 0
Filtered syslog:
None found
Thread 0 Crashed:
0 dyld 0x0375a3e4 0x03738000 + 0x223e4 // __abort_with_payload + 0x18
1 dyld 0x0375a04b 0x03738000 + 0x2204b // abort_with_payload_wrapper_internal + 0x41
2 dyld 0x0375a085 0x03738000 + 0x22085 // fcntl + 0x1
3 dyld 0x0373be73 0x03738000 + 0x3e73 // dyld::halt(char const*) + 0xf5
4 dyld 0x0373e603 0x03738000 + 0x6603 // dyld::_main(macho_header const*, unsigned long, int, char const**, char const**, char const**, unsigned long*) + 0x121f
5 dyld 0x037391d1 0x03738000 + 0x11d1 // dyldbootstrap::start(macho_header const*, int, char const**, long, macho_header const*, unsigned long*) + 0x145
6 dyld 0x03739040 0x03738000 + 0x1040 // _dyld_start + 0x40
Thread 0 crashed with ARM Thread State (32-bit):
r0: 0x00000000 r1: 0x00000000 r2: 0x00000000 r3: 0x038a1f98
r4: 0x0000005f r5: 0x038a1b98 r6: 0x00000000 r7: 0x038a1b64
r8: 0x00000000 r9: 0x0000005f r10: 0x00000000 r11: 0x00000000
ip: 0x00000209 sp: 0x038a1b24 lr: 0x0375a04b pc: 0x0375a3e4
cpsr: 0x40000010
Binary Images (dpkg):
0x000b4000 - 0x01f2bfff + Kodi armv7 <6d18973cabfa30eda7b222e31747ab37> /Applications/Kodi.app/Kodi {"install_date":"2017-02-01 00:06:09 -0600","name":"Kodi-iOS","identifier":"org.xbmc.kodi-ios","version":"17.0-0~rc4"}
Binary Images (App Store):
Binary Images (Other):
0x03738000 - 0x03763fff dyld armv7s <898b6b42ae3b3ffb8de9a96b7071f49d> /usr/lib/dyld
0x1ca80000 - 0x1ca81fff libSystem.B.dylib armv7s <6dd39877c56e3669bef87f28ffd83927> /usr/lib/libSystem.B.dylib
0x1d2da000 - 0x1d2e6fff libz.1.dylib armv7s <7fedbe86dff035d48ab88546a22571da> /usr/lib/libz.1.dylib
0x1d78f000 - 0x1dad1fff CoreFoundation armv7s <ff029a1d9d8b33d487ecae1351479200> /System/Library/Frameworks/CoreFoundation.framework/CoreFoundation
0x1ddb9000 - 0x1e08cfff CFNetwork armv7s <c7c685b16a9437cb88f293f1e55b6333> /System/Library/Frameworks/CFNetwork.framework/CFNetwork
0x1e0e8000 - 0x1e381fff Foundation armv7s <24f4575184cb3fb6b9b6e94b051517ae> /System/Library/Frameworks/Foundation.framework/Foundation
0x1ea89000 - 0x1ef66fff CoreGraphics armv7s <b586362fc6213d7b963143b6bd8c1b57> /System/Library/Frameworks/CoreGraphics.framework/CoreGraphics
0x1fb52000 - 0x1fb6dfff CoreVideo armv7s <29235247c3163f36abceeadf482cf6ab> /System/Library/Frameworks/CoreVideo.framework/CoreVideo
0x1fba7000 - 0x1fc93fff libiconv.2.dylib armv7s <0377fba9fb0337df8af353283425a80e> /usr/lib/libiconv.2.dylib
0x1fc94000 - 0x1fde0fff CoreAudio armv7s <8246c94526923b7b8843be4301c0b029> /System/Library/Frameworks/CoreAudio.framework/CoreAudio
0x1fde5000 - 0x1fec3fff CoreMedia armv7s <416b0680bb413b02917e6d6e3be3de05> /System/Library/Frameworks/CoreMedia.framework/CoreMedia
0x20041000 - 0x200bdfff VideoToolbox armv7s <7c29a63eb88e39ab8fb2e15a865b9298> /System/Library/Frameworks/VideoToolbox.framework/VideoToolbox
0x20226000 - 0x20650fff AudioToolbox armv7s <00a2ee8c2c543492be42336c283fd0cf> /System/Library/Frameworks/AudioToolbox.framework/AudioToolbox
0x20651000 - 0x207f8fff QuartzCore armv7s <4da6012956963f23b2bdf9e2ad5e7a76> /System/Library/Frameworks/QuartzCore.framework/QuartzCore
0x22928000 - 0x235f8fff UIKit armv7s <5ec4071af5003d7bb3bf2891a6b27b68> /System/Library/Frameworks/UIKit.framework/UIKit
0x23fb4000 - 0x2414efff AVFoundation armv7s <79a3f8cce7e839f4b4c9bb0010668f48> /System/Library/Frameworks/AVFoundation.framework/AVFoundation
0x26daf000 - 0x270dcfff MediaPlayer armv7s <0f83ce715a4a3a448ae01b00153173d7> /System/Library/Frameworks/MediaPlayer.framework/MediaPlayer
0x2d37d000 - 0x2d380fff libutil.dylib armv7s <40077dbd29f83f4380ac1d590c063607> /usr/lib/libutil.dylib
2017-02-02, 16:04
bash-4.0$ cd "/Applications/Kodi.app";./Kodi
dyld: Library not loaded: @executable_path/Frameworks/libsmbclient.dylib
Referenced from: /Applications/Kodi.app/./Kodi
/Applications/Kodi.app/./Frameworks/libsmbclient.dylib: required code signature missing for '/Applications/Kodi.app/./Frameworks/libsmbclient.dylib'
Abort trap: 6
bash-4.0$
Abort trap: 6
bash-4.0$
2017-02-03, 09:21
This indicates that the app was not properly signed... Has nothing to do with ios 10.2 ...
2017-02-04, 02:18
I think its a Jailbreak related. I had Kodi 17 up and running great on 10.1.1 and 10.2 stock but when I jailbroke i wasn't able to open Kodi, it just crashes immediately. Kodi is also listed as incompatible on the iOS 10 compatibility list, https://docs.google.com/spreadsheets/d/1...r0/pubhtml#. I have installed several apps using a signing service (i know, bad) since the jailbreak with no issues. Tried both Cydia and impactor as well with the same crashing result.
2017-02-04, 08:14
So, definitely a ailbreak issue. I uninstalled, rebooted into unjailbroken state and reinstalled 17. Working fine in both states now.
Additional info: Kodi was installed pre jailbreak and crashed at launch .all subsequent installs were done while jail broken, resulting in a crash.
The "immortal" tweak in default bigboss repo will allow for permanent signing of apps while jail broken, aiding in sodeloading kodi,
2017-02-06, 06:13
(2017-02-03, 09:21)Memphiz Wrote: [ -> ]This indicates that the app was not properly signed... Has nothing to do with ios 10.2 ...
The above error occurs on a jailbrokn iPad Air 2 using Yalu 10.2 beta 7.
2017-02-06, 10:12
I can't get it to work either. It crashes even with the Cydia immortal tweak. I'm using Yalu beta 7, iOS 10.2 jailbreak. I'm using an iPad Pro 9.7 inches. I previously had kodi installed on same device with an iOS 9.3.3 jailbreak and it was working.
2017-02-08, 23:52
Solution:
I have Kodi rc4 running great now on my iPhone 6 iOS 10 with Yalu v7. Heres what I did.
1. Uninstall Kodi
2. reboot phone
3. side load kodi (i use paid service) in nonJB environment
4. Run Yalu and JB
5. (optional) If using free developer acct. install Immortal via cydia (Bigboss repo) to extend app life.
Hope this works for others as well!
1. Uninstall Kodi
2. reboot phone
4. Run Yalu and JB
2017-02-09, 01:22
OK i am by no mean expert on ios JB however I am able to run the krypton nightly (i guess it was 17.1 rc1) but the version shouldn't matter.
I believe the signing in JB yalu is broken. The side load works but if you want normal Kodi installation to work then follow these steps.
What i did is simply signing the dylib and so files.
So run mobileterminal (install from Cydia if you don't have it)
logon as root so type
su
press enter and then enter root password. If you haven't changed it then default is alpine.
Now copy following line one by one press enter each time.
Last but not least, some streams were crashing Kodi and the log file was talking about H/W acceleration. After disabling the H/W acceleration it worked fine. This was tested on iPhone 6.
su
cd /Applications/Kodi.app
find $PWD/ -name *.so -exec ldid -S {} \;
find $PWD/ -name *.dylib -exec ldid -S {} \;
2017-02-09, 06:45
Thank you to Shani-08. Your 3 lines of code in previous post fixed the issue with running Kodi 17 on Yalu Jailbroken iOS 10. Kodi was the main reason I JB in the first place! Appreciate what you and others do to help out those of us who are just technical enough to understand what to do after someone else has figured out the fix.
2017-02-10, 10:11
Great thank for letting me know. I have updated my comments. Yeah I spent a day then lost faith and when I was browsing the crash log saw why it was crashing and tried my luck.
