Full Version: Newbie help - Kodi freezing or shutting channels down
Hi there
Apologies as I'm certain this question will have been asked on numerous occasions. I am new to Kodi and have downloaded onto my MacBook Air (OS X 10.12.3 and mainly use the live TV but I get a lot of freezing / buffering ...
Any suggestions as to how to avoid this?
Thanks in advance
What is the source of your TV channels?
Dangelus - how would I know?
PRVP IPT Simple Client
If you don't know where you are getting your TV channels from then I'm guessing they are less than legitimate.
If you didn't add them to your install then you are not using an official Kodi release as Kodi does not provide content.
(2017-01-29, 15:42)conans Wrote: [ -> ]PRVP IPT Simple Client
IPTV Simple Client is designed to be used with legitimate content provided to you from your ISP or content provider. If yours came pre-loaded with channels then they are most likely pirated streams (which we do not provide support for) and why you are having bandwidth issues.
Thanks Dangelus ... I'm not sure whether I'm doing something legitimate or not! Frustrated as I don't really know what contebt is provided to me by my ISP and what isn't. Thanks for your efforts anyway.
