2017-01-30, 20:35
2017-02-01, 08:54
why would you need the seconds too?
in the export templates you could take a different property which hold the runtime in seconds
2017-02-01, 09:54
Quote: why would you need the seconds too?For example to compare the length of different movie versions.
So I assume, it is not possible to show the exact run time in minutes and seconds, like e.g. 90 min. 33 sec.
Many thanks
2017-02-01, 17:05
after having a discussion with myron, I've changed the display of the runtime in the media files tab to a shorter version with seconds (so also trailer will be displayed nicely)
will be available in the next version
2017-02-01, 20:02
That is very great, many thanks mlaggner
