2017-01-31, 18:30
2017-01-31, 18:38
OS Windows 10
VisualStudio 2015
istall msys32 its ok
and next probelm
2017-01-31 16:34:07 (402 KB/s) - ‘ffmpeg-3.1.6-Krypton.tar.gz’ saved [11170735]
ffmpeg-3.1.6-Krypton.tar.gz ................................... [Extracting]
.ffmpeg-3.1.6-Krypton (32bit) ................................. [Configuring]
..gcc is unable to create an executable file.
If gcc is a cross-compiler, use the --enable-cross-compile option.
Only do this if you know what cross compiling means.
C compiler test failed.
If you think configure made a mistake, make sure you are using the latest
version from Git. If the latest version fails, report the problem to the
[email protected] mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "config.log" produced by configure as this will help
solve the problem.
ffmpeg-3.1.6-Krypton (32bit) ................................... [Compiling]
Makefile:2: config.mak: No such file or directory
Makefile:67: /common.mak: No such file or directory
Makefile:109: /libavutil/Makefile: No such file or directory
Makefile:109: /library.mak: No such file or directory
Makefile:111: /doc/Makefile: No such file or directory
Makefile:198: /tests/Makefile: No such file or directory
make: *** No rule to make target '/tests/Makefile'. Stop.
ffmpeg-3.1.6-Krypton (32bit) ........................................ [Done]
cp: cannot stat ‘/xbmc/lib/win32/ffmpeg/bin/*.dll’: No such file or directory
failed to compile /xbmc/system/avcodec-57.dll
VisualStudio 2015
and next probelm
solve the problem.
2017-02-01, 10:56
Its ok i have what is problem
Delete my previus installed Cygwin64...
OS windows 10
VS2015
must change DownloadMingwBuildEnv.bat line 26 set msys2=msys64 to set msys2=msys32
and make-mingwlibs.bat line 13 SET msys2=msys64 to SET msys2=msys32
64 bit not download gnutls-3.4.14-static from http://ftp.halifax.rwth-aachen.de/xbmc/b...s2/locals/ find file x86_68-gnutls-3.4.14-static.tar.gz
OS windows 10
VS2015
