I have added a few movies to the Kodi 16.1 with create movie sets automatically enabled. But some movies in the series are not added to the collections. I tried to add them by managing the sets but failed.
Is there any way to customize these movie sets to add / remove movies manually?
Movie sets (wiki) should not be an issue, find the set, with the set in focus hit 'c' on the keyboard to bring up the context menu and pick manage, then manage movie set, a requester will pop up with ALL the listings in your library, with one or more of the set's highlighted. At this point find other items to highlight, (or UN-highlight) that are to be in the set or not. Chose art is the fun part. Where are you failing?
Manually setting <sets> in the .nfo is much more painful. Perhaps another re-scrape will place the <sets> tag for you?
I was new to Kodi and I did not understand the options in "Manage Movie Set" menu. Now I got it.
