guys i know e asked the question many times . but i could not get to do it .
some people suggest dropbox but drop box is not working with apple tv 4 . at least in mine .
is there anyway not that complicated to transfer zip file to apple tv for kodi purpose .
it will be great when you suggest to explain step by step how to do it ?
thank you for you time and god bless this community . always appreciate with or without success .
ps: kodi is sideloaded this apple tv 4 is not jailbroken . so i think can not use cyberduck .
(2017-02-02, 22:04)Japgeisha Wrote: [ -> ]is there anyway not that complicated to transfer zip file to apple tv for kodi purpose .
Install the CyberDuck app on your MacBook, connect the MacBook to the same network as your ATV4, enter your ATV4's IP address into the CyberDuck app, copy/paste the files into your "mobile" root folder on the ATV4. I think that should work - and don't forget to donate to the Devs of CyberDuck.
(2017-02-02, 22:12)ItsJuniorJ Wrote: [ -> ] (2017-02-02, 22:04)Japgeisha Wrote: [ -> ]is there anyway not that complicated to transfer zip file to apple tv for kodi purpose .
u can use cyberduck only if the apple tv is jailbroken mine is sideloaded
(2017-02-02, 22:08)Dangelus Wrote: [ -> ]Put your zip file in a network shared directory such as a smb share and then look for it in Kodi.
http://kodi.wiki/view/File_sharing
smb is for windows i did state i have MacBook .
and the apple tv 4 is not jailbroken so no ssh into it . its sideloaded with kodi .
(2017-02-03, 00:44)Japgeisha Wrote: [ -> ] (2017-02-02, 22:08)Dangelus Wrote: [ -> ]Put your zip file in a network shared directory such as a smb share and then look for it in Kodi.
Macs can do it too.
http://kodi.wiki/view/SMB/Mac
Regardless, it was just an example. Pick a network sharing protocol, Kodi can connect to quite a few as the previous link explains. Even Mac AFP shares.
(2017-02-03, 00:50)Dangelus Wrote: [ -> ] (2017-02-03, 00:44)Japgeisha Wrote: [ -> ] (2017-02-02, 22:08)Dangelus Wrote: [ -> ]Put your zip file in a network shared directory such as a smb share and then look for it in Kodi.
Macs can do it too.
i thank you so much for keeping up with me .
I'm sorry i did fallow all instruction in my mac exactely as it says .
but when i went to kodi on my apple tv 4th gen
went to instal from zip file under windows network (smb) when i hit i get ERROR 2
hare not available
what I'm missing .??
very sorry dont know how the kodi will know where the file is . thx for your time
(2017-02-03, 00:50)trogggy Wrote: [ -> ] (2017-02-03, 00:44)Japgeisha Wrote: [ -> ] (2017-02-02, 22:08)Dangelus Wrote: [ -> ]Put your zip file in a network shared directory such as a smb share and then look for it in Kodi.
Eh?
we love to have your solution if u know instead of Eh?
i did fallow the link instruction and can not connect . still have no access to my file shared still in trouble
For users that are jailbroken you dont need to host it on your Mac, just simply use the web. Host the file on mediafire then use wget to get it on your Apple TV. Navigate to the file in Kodi and install zip file, done. When using the link from media fire make sure you click the download button and grab the actual download button link. For example:
If I wanted this
http://www.mediafire.com/file/dzr0tzdzrn...b-tvos.ipa I would click the link and get the link on the download button which is this:
http://download1480.mediafire.com/d81wyf...b-tvos.ipa
But its only temporary so you can only use that temporarily link for a day or so.
Once you are ready to grab it just use wget:
wget
it will save to the root of the Apple TV by default which kodi can access through its file browser when searching for a zip instead.
(2017-02-04, 00:26)kuzn Wrote: [ -> ]For users that are jailbroken you dont need to host it on your Mac, just simply use the web. Host the file on mediafire then use wget to get it on your Apple TV. Navigate to the file in Kodi and install zip file, done. When using the link from media fire make sure you click the download button and grab the actual download button link. For example:
If I wanted this http://www.mediafire.com/file/dzr0tzdzrn...b-tvos.ipa I would click the link and get the link on the download button which is this:
wget http://download1480.mediafire.com/d81wyf...b-tvos.ipa
god bless you . i did upload the file in media fire but I'm lost how to use wget I'm little stuck first time i use this .
i searched how to use wget but could not find how . plz if u can help mere with little step by step thx bless you
i know u r just giving me an example but the file i want is .zip and not ipa thx
( update ):
i downloaded wget utility i opened terminal wget and past th link in form of http:// from (media fire)
hit enter download went through . but nothing went to apple tv 4th /
i checked the kodi root nothing . first if no ssh then no connection between my mnacbook and the apple tv 4 . I'm confused hhh sorry
should i be connected to appletv4th using type while I'm doing transfer ? hmm
Once you ssh into your jailbroken aTV4 you then use wget. The wget command downloads the file directly to your aTV4. No need to download the file onto your computer and no need to download wget, it automatically installs wget on your aTV4 when its jailbroken with pangu.
kuzn if you did read my thread we wouldn't be wasting time .
i did say my Apple TV 4 is not jailbrokennnnn it has kodi sideloaded
and there is no way you ssh if its not jailbroken .
so your suggestion is useless .
I'm sorry .
