Full Version: Saving LRC files
I'm sure the answer is no but I was wondering if there was a way to save the LRC lyric files from MiniLyrics while playing music.
I just really like having everything stored locally... offline use... internet down, whatever.
I had considered embedding lyrics in my idtags but obviously the LRC files scrolling lyrics is much nicer then a screen full of static text.
The cu-lrc lyrics add-on has a minilyrics scrapper, and yes, you can save .lrc's through it.
(2017-02-03, 02:54)host505 Wrote: [ -> ]The cu-lrc lyrics add-on has a minilyrics scrapper, and yes, you can save .lrc's through it.
Don't know what my deal is these last two days not looking thoroughly through settings Confused
Got it.... thank you.
