Kodi has been updated from Jarvis to Krypton on my phone and now crashes whilst loading. I have found the logs and config files, what tag do I need to set to turn on debug logging so that I can post it.
Try installing the 64bit version
(2017-02-06, 23:39)Martijn Wrote: [ -> ]Try installing the 64bit version
The 64bit version won't work with his armv7 cpu correct?
There are two requirements for running the 64 bit build AFAIK:
64 bit processor
AND
64 bit android.
Given that the log shows it running a 32 bit kernel, and the Arm7 is 32 bit, the 64 bit version shouldn't work.
But if Martijn says so, give it a whirl.
I have already tried installing the 64bit version and it fails to install
Sent from my PE-TL10
Any ideas on what I can try to resolve this.
