Full Version: Kodi won't play DVB-T2 channels (hevc / h265)
Hi All,
I've got the issue, Kodi won't play DVB-T2 channels, I start such a channel the buffering window opens, but stuck at 0%
My System:
TVH 4.0.9-16 via Ubuntu 14.04 LTS with an August T230
Kodi 16.1:
To exclude hardware issues, running on a Win 7 in the same network with the linux server
The DV-T2 streams are playable, for example VLC is playing very well....
Kodi gave back following log:
13:06:23 T:14988   DEBUG: Thread DVDPlayer start, auto delete: false
13:06:23 T:14988  NOTICE: Creating InputStream
13:06:23 T:14988   DEBUG: PVRManager - PVR::CPVRManager::OpenLiveStream - opening live stream on channel 'Das Erste HD'
13:06:23 T:14988   DEBUG: opening live stream for channel 'Das Erste HD'
13:06:23 T:14988   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux open
13:06:23 T:14988   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux subscribe to 252861906
13:06:23 T:14988   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux successfully subscribed to channel id 252861906, subscription id 3
13:06:23 T:12660   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - demux unhandled subscription message [subscriptionGrace]
13:06:23 T:14988   DEBUG: PVRFile - XFILE::CPVRFile::Open - playback has started on filename pvr://channels/tv/Alle Kanäle/pvr.hts_252861906.pvr
13:06:23 T:14988   DEBUG: CDVDInputStreamPVRManager::Open - stream opened: pvr://channels/tv/Alle Kanäle/pvr.hts_252861906.pvr
13:06:23 T:14988  NOTICE: Creating Demuxer
13:06:23 T:14988   ERROR: CSelectionStreams::Get - failed to get stream
13:06:23 T:14988   DEBUG: CDVDPlayer::SetCaching - caching state 2
13:06:23 T:14988 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
13:06:23 T:14988 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
13:06:23 T:14988   DEBUG: CApplication::OnPlayBackStarted: play state was 1, starting 1
13:06:23 T:12528   DEBUG: CApplication::PlayFile: OpenFile succeed, play state 2
13:06:23 T:12528   DEBUG: CApplication::OnPlayBackStarted: play state was 2, starting 0
13:06:23 T:12528   DEBUG: ------ Window Init (DialogSeekBar.xml) ------
13:06:23 T:12528   DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Alle Kanäle/pvr.hts_252861906.pvr)
13:06:23 T:12528   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
13:06:23 T:12528   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
13:06:23 T:12528   DEBUG: AddOnLog: Tvheadend HTSP Client: pvr.hts - Announce(flag=Player, sender=xbmc, message=OnPlay)
All hints are welcome, hope you can help me....
Thanks,
WebEye
If you make a recording of the HEVC DVB-T2 stream and try playing it as a file in VLC and Kodi - does it play in both?
Does your version of Kodi definitely replay HEVC content?
Sorry for late answer,
in week I'm very busy!
I've solved this issue by installing the unstable TVH version for full DVB-T2 support!
Thanks anyway,
WebEye
