2017-02-07, 00:08
ive posted this question on another sight with no success. So dont feel like making a long drawn out post,so going to make it short and seet.
useing RPI3 mb RUNNING OSMC
Having issues with the context menu operation.
This key map code disableds the C function to enable the context menu.
This key map code enables the menu button on the beybored (right click) and remote for the context menu
Each of these codes work perfect individually in a .XML file in the keymap DIR, but i cant figure a way to get them to work at the samevtime or combine the files. Any help would be much appreciated, THANKS IN ADVANCE
<keymap>
<global>
<keyboard>
<c mod="alt,ctrl,shift">ContextMenu</c>
<c>noop</c>
</keyboard>
</global>
<fullscreenvideo>
<keyboard>
<c>Playlist</c>
</keyboard>
</fullscreenvideo>
</keymap>
<keymap><global><keyboard><key id="61656">contextmenu</key></keyboard></global></keymap>
