Full Version: Setup VLC as External Player
After setting up Allcast as an External Player, I am familiar with the process and with the playercorefactory.xml file but not all the details of the parameters
I have found various playercorefactory.xml files with different entries for VLC Player but non work for me.
I guess one critical one is the filename parameter, which presumably tells the program the location of the Player executable
One file uses com.vlcforandroid.vlcdirectprofree for this
Another uses /usr/bin/vlc
Others use definitions obviously intended for a Windows platform.
I guess this needs to be tailored to the particular Android build
My devise is a Hudl Android 5.1 x86_64.
Any suggestions for a filname to use or how I might get this from my file system. I am not rooted
I presume you've seen this on the wiki? - HOW-TO:Use external players on Android (wiki).
If you use a file manager app and look in the Android folder and within that a data folder. Inside that you should find sub-folders for each app you have installed (kodi is found in org.xbmc.kodi for example). There should be one in there for VLC - that's the name you need to use (it may be your com.vlcforandroid.vlcdirectprofree example above, but it might be something different depending on what you have installed).
Hi Darren
Thanks very much for your prompt reply.
Would you believe it, I had already tried that ( filename org.videolan.vlc ) and it didn't work.
However, your reply prompted me to look again at the script I had created and I discovered that the reason for the failure was not the filename but another careless error which I had introduced into the script.
So, thank you very much. I now have a script through which by using Play Using, I have the choice of Casting or playing locally with my preferred player.
I also notice that Video Player comes up in the choice of players, which is the Kodi player.
Great isn't it !
Phil
Thread marked solved.
Hi Phil, I am going through the same issue but even though I believe I have the playercorefactory.xml file correct, it does not seem to work for me. It continues to default to Kodi player.
This is what I have:
<playercorefactory>
    <players>
        <player name="VLCPlayer"  Type="ExternalPlayer" audio="false" video="true">
        <filename>org.videolan.vlc></filename>
        <hidexbmc>true</hidexbmc>
        <playcountminimumtime>120</playcountminimumtime>
    </players>
    <rules>
        <rule action="prepend">
        </rule>
        <rule filetypes="avi|mkv|mp4|mpg|mpeg" player="VLC">
        </rule>
    </rules>
</playercorefactory>
Any advice on how I can tweak this to get it working as yours does?
(2018-02-26, 15:28)nhl_vibc Wrote: [ -> ]Hi Phil, I am going through the same issue but even though I believe I have the playercorefactory.xml file correct, it does not seem to work for me. It continues to default to Kodi player.
<playercorefactory>
    <players>
    </players>
    <rules>
        </rule>
        </rule>
    </rules>
looks like you have an extra >
I'm trying to use VLC as my player so I can watch locally or cast to chromecast. The kodi streams tries to open in VLC but I am met with the error that says "The location (full https link) cannot be played". Also when I long press and hit play with... And choose video player or mx it still attempts to open in VLC. I have also attached my xml file contents.
[syntax=xml]
<playercorefactory>
<players>
<player name="MXPlayerFree" type="ExternalPlayer" audio="false" video="true">
<filename>com.mxtech.videoplayer.ad</filename>
</player>
<player name="MXPlayerPro" type="ExternalPlayer" audio="false" video="true">
<filename>com.mxtech.videoplayer.pro</filename>
</player>
<player name="TPlayer" type="ExternalPlayer" audio="false" video="true">
<filename>com.tiantian.android.player.app</filename>
</player>
<player name="DicePlayerFree" type="ExternalPlayer" audio="false" video="true">
<filename>com.inisoft.mediaplayer.trial</filename>
</player>
<player name="VLCPlayer" type="ExternalPlayer" audio="false" video="true">
<filename>org.videolan.vlc</filename>
</player>
<player name="DicePlayerPaid" type="ExternalPlayer" audio="false" video="true">
<filename>com.inisoft.mediaplayer.a</filename>
</player>
<player name="RockPlayerLite" type="ExternalPlayer" audio="false" video="true">
<filename>com.redirectin.rockplayer.android.unified.lite</filename>
</player>
<player name="RockPlayer" type="ExternalPlayer" audio="false" video="true">
<filename>com.rockplayer</filename>
</player>
<player name="BSPlayerFree" type="ExternalPlayer" audio="false" video="true">
<filename>com.bsplayer.bspandroid.free</filename>
</player>
<player name="MoboplayerFree" type="ExternalPlayer" audio="false" video="true">
<filename>com.clov4r.android.nilz</filename>
</player>
<player name="mVideoplayerFree" type="ExternalPlayer" audio="false" video="true">
<filename>afzkl.development.mVideoPlayer</filename>
</player>
<player name="Vplayer" type="ExternalPlayer" audio="false" video="true">
<filename>me.abitno.vplayer.t</filename>
</player>
<player name="WondersharePlayer" type="ExternalPlayer" audio="false" video="true">
<filename>com.wondershare.player</filename>
</player>
<player name="ArchosVideo" type="ExternalPlayer" audio="false" video="true">
<filename>com.archos.mediacenter.video</filename>
</player>
<player name="SopCast" type="ExternalPlayer" audio="false" video="true">
<filename>org.sopcast.android</filename>
</player>
<player name="DaroonPlayer" type="ExternalPlayer" audio="false" video="true">
<filename>com.daroonplayer.dsplayer</filename>
</player>
</players>
<rules action="prepend">
********** EDIT THIS SECTION **********
<rule protocols="smb" player="VLCPlayer"/>
<rule dvdimage="true" player="VLCPlayer"/>
<rule protocols="rtmp" player="VLCPlayer"/>
<rule protocols="rtsp" player="VLCPlayer"/>
<rule protocols="sop" player="VLCPlayer"/>
<rule internetstream="true" player="VLCPlayer"/>
<rule video="true" player="VLCPlayer"/>
<!-- Default for anything else not listed -->
</rules>
</playercorefactory>/syntax]
<playercorefactory>
<players>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</player>
</players>
</rules>
