(2017-04-05, 09:15)JohnyBee Wrote: [ -> ] (2017-04-03, 15:12)melons2 Wrote: [ -> ](...)
I can not figure this out?
This is also a mystery to me.
What operating system do you have?
Maybe there is a problem here?
I am using Windows 10.
it may be a extendedinfo script or LastFM script error:
07:11:58.563 T:9752 WARNING: CPythonInvoker(41, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:11:58.895 T:10980 ERROR: NEWADDON Unknown Music Info Key "path"
07:11:59.200 T:10980 ERROR: Previous line repeats 9 times.
07:11:59.200 T:10980 WARNING: CPythonInvoker(39, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:02.729 T:12016 ERROR: NEWADDON Unknown Music Info Key "path"
07:12:02.857 T:12016 ERROR: Previous line repeats 24 times.
07:12:02.857 T:12016 WARNING: CPythonInvoker(40, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:04.449 T:16516 WARNING: CPythonInvoker(45, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:25.218 T:13872 WARNING: CPythonInvoker(49, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\default.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:25.662 T:7108 ERROR: NEWADDON Unknown Music Info Key "path"
07:12:25.838 T:7108 ERROR: Previous line repeats 6 times.
07:12:25.838 T:7108 WARNING: CPythonInvoker(46, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:29.094 T:6968 WARNING: CPythonInvoker(53, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:29.296 T:12060 ERROR: NEWADDON Unknown Music Info Key "path"
07:12:29.388 T:12060 ERROR: Previous line repeats 24 times.
07:12:29.388 T:12060 WARNING: CPythonInvoker(48, C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\script.extendedinfo\plugin.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmcgui:
ialogBusy
07:12:30.452 T:4668 ERROR: CImageLoader:
oWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/videocodec/
07:12:30.453 T:4668 ERROR: CImageLoader:
oWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/videoresolution/
oWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/aspectratio/
07:12:30.454 T:4668 ERROR: CImageLoader:
oWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/audiocodec/
oWork - Direct texture file loading failed for resource://resource.images.mediaicons.coloured/recordlabel/
07:12:43.418 T:8672 ERROR: CImageLoader:
07:12:43.420 T:8672 ERROR: CImageLoader:
07:12:43.421 T:8672 ERROR: CImageLoader:
07:12:43.433 T:8672 ERROR: CImageLoader:
07:12:45.032 T:13348 ERROR: XFILE::CDirectory::GetDirectory - Error getting
07:12:50.799 T:15196 NOTICE: Storing total System Uptime
07:12:50.799 T:15196 NOTICE: Saving settings
07:12:50.810 T:15196 NOTICE: Saving skin settings
07:12:50.827 T:15196 NOTICE: stop all
07:12:50.827 T:15196 NOTICE: stop player
07:12:50.827 T:15196 NOTICE: ES: Stopping event server
07:12:50.827 T:15196 NOTICE: stopping upnp
07:12:50.890 T:8228 NOTICE: ES: UDP Event server stopped
07:12:50.980 T:15196 NOTICE: CWebServer[8080]: Stopped
07:12:51.170 T:15196 NOTICE: clean cached files!
07:12:51.505 T:3920 NOTICE: Skin Helper Service --> Shutdown requested !
07:12:51.509 T:3920 NOTICE: Skin Helper Service --> Skin Helper Service version 1.1.13 stopped
07:12:51.608 T:8388 NOTICE: script.tv.show.next.aired: ### abort requested -- stopping background processing
07:12:51.612 T:14408 NOTICE: NEXTUP SERVICE NOTIFICATION Service -> ======== STOP NEXTUP SERVICE NOTIFICATION ========
07:12:51.614 T:14408 WARNING: CPythonInvoker(5, C:\Users\silki_000\AppData\Roaming\Kodi\addons\service.nextup.notification\service.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\service.nextup.notification\service.py" has left several classes in memory that we couldn't clean up. The classes include: class XBMCAddon::xbmc:
layer,class XBMCAddon::xbmcaddon::Addon,class XBMCAddon::xbmcaddon::Addon
07:12:56.951 T:6956 NOTICE: Skin Helper Widgets --> Backgroundservice stopped
07:12:56.954 T:3468 NOTICE: Skin Helper Backgrounds --> BackgroundsUpdater - stop called
07:12:56.956 T:4496 WARNING: CPythonInvoker(19, C:\Users\silki_000\AppData\Roaming\Kodi\addons\service.scrobbler.lastfm\scrobbler.py): the python script "C:\Users\silki_000\AppData\Roaming\Kodi\addons\service.scrobbler.lastfm\scrobbler.py" has left several classes in memory that we couldn't clean up. The classes include: class PythonBindings::XBMCAddon_xbmc_Player_Director,class PythonBindings::XBMCAddon_xbmc_Monitor_Director
07:12:57.127 T:15196 NOTICE: closing down remote control service
07:12:57.528 T:15196 NOTICE: stopped
07:12:57.729 T:15196 NOTICE: destroy
07:12:57.729 T:15196 NOTICE: unload skin
07:12:57.841 T:15196 NOTICE: unload sections
07:12:57.848 T:15196 NOTICE: special://profile/ is mapped to: special://masterprofile/
07:12:57.853 T:15196 NOTICE: application stopped...
I repeated running Estuary and emiralles MQ7 MOD skin from statup and didn't get these errors.
I guess it is something in the Wanilton Mq7 skin.aeonmq7-2.0.6.8 have some error...............not sure.
