Jango is appearing in menu but music won't play. Gives an error to check file log? I check log files and they appear empty. I have also tried to reinstall this add on and doesn't work. Any suggestions?
This is a music addon question, so moving it there.
There is a bug in the default.py source
I have fixed the exception, and it seems that all the rest is working
https://github.com/barsuk1/kodi
At my system the file is under C:\Users\<user_name>\AppData\Local\Packages\XBMCFoundation.Kodi_4n2hpmxwrvr6p\LocalCache\Roaming\Kodi\addons\plugin.audio.jango
Thank you!!! Now workingÂ
When I go on "Fullscreen playback" on the kodi.log file I can see some errors but maybe the url generated is incorrect:
ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for
http://m4a-64.cdn107.com/05/42/22/cdart.png
or
http://m4a-64.cdn107.com/06/24/81/cdart.png
I tried to open from browser and obtained:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>52CF4E26C953E59F</RequestId>
<HostId>
Es4aHt0I4pBk24irRYYKD/FPCMWXPc1Z2p+03Crxgrg0uvrHPlpvN5r4SSayLYec+tET4X7EmTY=
</HostId>
</Error>
