Full Version: No sound on local MKV files since Krypton upgrade
Going to have to revert to 16 if I can't find a solution. No changes were made from I've version to another and everything was working fine before. High end Pioneer Elite receiver that can play everything!
Cheers
Update: seems to affect only DTS movies
Thread moved to OS independent for a lack of any useful information at all on device or OS.
Best guess: OP uses an android box which can not make DTS passthrough since removal of the old PCM PT way...
Turn off passthrough.
(2017-02-07, 20:47)Gracus Wrote: [ -> ]Best guess: OP uses an android box which can not make DTS passthrough since removal of the old PCM PT way...
Mini M8S. Like I mentioned everything was working fine before the upgrade.
Downgrade time!
Edit : I'm back with 16.1 and all is well again with passthrough turned on as it was before. Didn't like the layout of 17 anyway, given there wasn't a home screen similar to the one before.
Downgrade time? You haven't even posted a debug log (wiki). Did you come here just to waste our time?
(2017-02-12, 06:24)nickr Wrote: [ -> ]Downgrade time? You haven't even posted a debug log (wiki). Did you come here just to waste our time?
Waste your time? Not really, but I was just coming to this forum to see if the friendly Kodi people could help me with a problem that was non existent with a previous version. I never got to get the debug thing to work in the past hence why there wasn't one.
I'll keep monitoring other forums to see if others are experiencing the problem I was so don't worry, I won't be wasting your time anymore.
Been using XBMC and Kodi for a few years and it's been great. It just gets frustrating when all of a sudden it doesn't work like it used to.
And yet you don't seem to have responded to the suggestion made, or provided normal debug info.
