Full Version: RC1 - Some problems whit Estuary...
On log appears so many error like this:
19:41:51.079 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:41:51.079 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:42:01.737 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:42:01.737 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:42:04.676 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:42:04.676 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:42:12.414 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:42:12.414 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:43:14.651 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:43:14.652 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:43:16.381 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:43:16.381 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
19:43:17.724 T:1958454192   ERROR: COMXImageFile::ReadFile special://skin/extras/backgrounds/pattern1.jpg not found
19:43:17.724 T:1958454192  NOTICE: LoadJpeg: unable to load special://skin/extras/backgrounds/pattern1.jpg
I use the current release of OSMC on a Pi2 based on Kodi 17.1-RC1...... it's normal ?
*EDIT*
mmmmmmmmmmmmm... interesting. I restart my Pi2 and all errors it's disappering.... if i have so other i re-edit this thread.
Well I have that problem now where my posters are not being loaded and the my log shows the same errors you are getting.
09:00:43.216 T:1958933424  NOTICE: initialize done
09:00:43.216 T:1958933424  NOTICE: Running the application...
09:00:43.228 T:1958933424  NOTICE: starting zeroconf publishing
09:00:43.229 T:1958933424  NOTICE: CWebServer[8080]: Started
09:00:43.229 T:1958933424  NOTICE: starting upnp client
09:00:43.233 T:1607726064  NOTICE: ES: Starting UDP Event server on port 9777
09:00:43.233 T:1607726064  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
09:00:44.040 T:1565783024   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
09:00:44.049 T:1565783024   ERROR: Previous line repeats 1 times.
09:00:44.049 T:1565783024  NOTICE: LoadJpeg: unable to load nfs....-poster.jpg
09:00:44.099 T:1691874288   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
09:00:44.112 T:1691874288   ERROR: Previous line repeats 1 times.
09:00:44.113 T:1691874288  NOTICE: LoadJpeg: unable to load nfs....-poster.jpg
09:00:44.159 T:1565783024   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
09:00:44.167 T:1938813936   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
09:00:44.167 T:1938813936  NOTICE: LoadJpeg: unable to load nfs....-poster.jpg
09:00:44.176 T:1565783024   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
09:00:44.176 T:1565783024  NOTICE: LoadJpeg: unable to load nfs....-poster.jpg
09:00:44.232 T:1938813936   ERROR: COMXImageFile::ReadFile nfs....-poster.jpg not found
I have two RPis running same version of Kodi 17, one of them loads the files with no issues and the other doesn't.
I still look for possible solutions. Will be happy for help. (replaced the path to jpg with '....')
Looks like it's trying to load images from a network mount and it can't. Is your network fully up? If that, that's probably your problem. To fix, ensure your network is fully up before starting Kodi.
My network is fully up. I also restated it and then restarted kodi and same thing. I get same errors.
