No matter which device I use (Windows Laptop, Fire Tv, or MI Box) whenever I put Kodi 17 (current release from Google play) on it, the WNBC Programs add-on does not work. You can enter the add-on, view list of shows, then view list of episodes, but when you click to watch the episode, it does NOTHING!
I switch back to a device running Kodi 16.1 Jarvis, and it works like a charm!
Can someone please fix this add-on and make it work with Krypton?
Thanks,
Wow, 86 views, but not one response, suggestion, etc?
I had a similar problem with the WCBS addon. Installing the rtmp input addon resolved my problem.
(2017-02-09, 17:09)jmooremcc Wrote: [ -> ]I had a similar problem with the WCBS addon. Installing the rtmp input addon resolved my problem.
Jmooremcc.....where can I find this rtmp input add-on. Did a Google search and it seems like most say 17 Krypton doesn't support this, and uses something different?
Confused.....
But if you have a link or something to share on where I can find it I will give it a try!
Thanks,
The WNBC add-on is working fine. RTMP has nothing to do with it.
Some US ISPs have weird re-directs for a couple of the major network sites.
You will need to post a debug log to xbmclogs.com or pastebin.com
PLEASE DO NOT create new threads to ask about add-ons. Use the support thread which is:
http://forum.kodi.tv/showthread.php?tid=222071
I will close this thread so that it doesn't keep dribbling on.
