Full Version: CU LRC Lyrics - Skin Estuary
Hello,
is it possible to change the window of the CU LRC Lyrics addon in the skin Esturary. Whe i start a music file, I see only the big screen from the
Lyrics window, and nothing else from the fanart.
- only the lyrics on the screen in front of the fanart
- no windo and no frames
May a like bit like Aeon Nox #smile#
Claus
Hi,  did you ever work out how to do this?
I am trying to do the same
Cheers
You can create a custom script-cu-lrclyrics-main.xml with the following content:
Quote:<?xml version="1.0" encoding="UTF-8"?>
<window>
    <animation type="WindowOpen" reversible="false">
        <effect type="zoom" start="80" end="100" center="960,540" delay="160" tween="back" time="240" />
        <effect type="fade" delay="160" end="100" time="240" />
    </animation>
    <animation type="WindowClose" reversible="false">
        <effect type="zoom" start="100" end="80" center="960,540" easing="in" tween="back" time="240" />
        <effect type="fade" start="100" end="0" time="240" />
    </animation>
    <depth>0.50</depth>
    <coordinates>
        <left>570</left>
        <top>130</top>
    </coordinates>
    <controls>
        <control type="image">
            <description>background image</description>
            <left>0</left>
            <top>0</top>
            <width>1345</width>
            <height>775</height>
            <texture colordiffuse="F8FFFFFF">culrc-dialog-bg-solid.png</texture>
        </control>
            <description>Dialog Header image</description>
            <left>0</left>
            <top>0</top>
            <width>1345</width>
            <height>70</height>
            <texture colordiffuse="FF12B2E7" border="2">culrc-white70.png</texture>
        </control>
        <control type="label">
            <description>header label</description>
            <textoffsetx>70</textoffsetx>
            <left>-30</left>
            <top>0</top>
            <width>1345</width>
            <height>70</height>
            <font>font32_title</font>
            <label>$INFO[MusicPlayer.Title]  [Songtext]</label>
            <align>left</align>
            <aligny>center</aligny>
            <shadowcolor>black</shadowcolor>
        </control>
        <control type="button">
            <description>background close area</description>
            <left>-1920</left>
            <top>-1080</top>
            <width>5760</width>
            <height>3240</height>
            <texturefocus>-</texturefocus>
            <texturenofocus>-</texturenofocus>
            <onclick>Action(close)</onclick>
        </control>
            <description>button overlay to avoid closing in dialog area</description>
            <left>0</left>
            <top>0</top>
            <width>1345</width>
            <height>765</height>
            <onclick>noop</onclick>
        </control>
        <control type="radiobutton">
            <description>logo</description>
            <left>1345</left>
            <top>11</top>
            <width>48</width>
            <height>48</height>
            <radiowidth>48</radiowidth>
            <radioheight>48</radioheight>
            <label></label>
            <animation effect="slide" end="-70,0" time="0" condition="true">Conditional</animation>
            <textureradioofffocus colordiffuse="EEFFFFFF">culrc-close.png</textureradioofffocus>
            <textureradiooffnofocus colordiffuse="EEFFFFFF">culrc-logo.png</textureradiooffnofocus>
            <textureradioonfocus colordiffuse="EEFFFFFF">culrc-close.png</textureradioonfocus>
            <textureradioonnofocus colordiffuse="EEFFFFFF">culrc-logo.png</textureradioonnofocus>
        </control>
        <!-- ** Required ** Do not change <id> or <type> (Lyrics, will autoscroll if lrc based lyrics are shown) -->
        <control type="list" id="110">
            <left>10</left>
            <top>110</top>
            <width>1325</width>
            <height>590</height>
            <onleft>111</onleft>
            <onright>111</onright>
            <onup>110</onup>
            <ondown>110</ondown>
            <pagecontrol>111</pagecontrol>
            <scrolltime>200</scrolltime>
            <itemlayout height="60">
                    <left>0</left>
                    <top>0</top>
                    <width>1325</width>
                    <height>60</height>
                    <font>font14</font>
                    <align>center</align>
                    <label fallback="--">$INFO[ListItem.Label]</label>
                </control>
            </itemlayout>
            <focusedlayout height="60">
                    <left>0</left>
                    <top>0</top>
                    <width>1325</width>
                    <height>60</height>
                    <font>font14</font>
                    <textcolor>FF12B2E7</textcolor>
                </control>
            </focusedlayout>
        </control>
            <description>Pick label</description>
            <left>10</left>
            <top>0</top>
            <width>1325</width>
            <height>70</height>
            <label>$ADDON[script.cu.lrclyrics 32005]</label>
            <visible>Control.IsVisible(120) + !Control.IsVisible(110)</visible>
        </control>
        <!-- ** Required ** Do not change <id> or <type> (Lyrics Chooser, if multiple lyrics are available) -->
        <control type="list" id="120">
            <left>10</left>
            <top>110</top>
            <width>1325</width>
            <onleft>121</onleft>
            <onright>121</onright>
            <onup>120</onup>
            <ondown>120</ondown>
            <pagecontrol>121</pagecontrol>
            <animation effect="slide" start="0,0" end="20,0" time="0" condition="!Control.IsVisible(121)">Conditional</animation>
            <itemlayout height="40">
                    <left>10</left>
                    <top>0</top>
                    <width>530</width>
                    <height>40</height>
                    <font>font14</font>
                    <label>$INFO[ListItem.Label]</label>
                </control>
            </itemlayout>
            <focusedlayout height="40">
                    <left>10</left>
                    <top>0</top>
                    <width>530</width>
                    <height>40</height>
                    <font>font14</font>
                </control>
            </focusedlayout>
        </control>
            <left>636</left>
            <top>790</top>
            <width>48</width>
            <height>24</height>
            <texturefocus colordiffuse="FF12B2E7">culrc-arrowdown.png</texturefocus>
            <texturenofocus colordiffuse="FF12B2E7">culrc-arrowdown.png</texturenofocus>
            <animation effect="zoom" start="100,0" end="100,100" center="auto" time="200" delay="10">VisibleChange</animation>
            <animation effect="zoom" start="100,0" end="100,100" delay="500" center="auto" time="200">WindowOpen</animation>
            <animation effect="zoom" start="100,100" end="100,0" center="auto" time="200">WindowClose</animation>
            <onclick>SetFocus(110)</onclick>
            <onclick>PageDown</onclick>
            <visible>Container(110).HasNext + Control.IsVisible(110)</visible>
        </control>
            <left>636</left>
            <top>-40</top>
            <width>48</width>
            <height>24</height>
            <texturefocus colordiffuse="FF12B2E7" flipy="true">culrc-arrowdown.png</texturefocus>
            <texturenofocus colordiffuse="FF12B2E7" flipy="true">culrc-arrowdown.png</texturenofocus>
            <onclick>PageUp</onclick>
            <visible>Container(110).HasPrevious + Control.IsVisible(110)</visible>
        </control>
            <description>lyricslist</description>
            <left>15</left>
            <top>710</top>
            <width>64</width>
            <height>64</height>
            <texture>culrc-contextmenu.png</texture>
            <visible>!String.IsEmpty(Window(Home).Property(culrc.haslist))</visible>
        </control>
            <description>Scraper label</description>
            <left>0</left>
            <top>740</top>
            <width>1325</width>
            <height>30</height>
            <label>$LOCALIZE[21870]: $INFO[Control.GetLabel(200)]</label>
            <font>font12</font>
            <align>right</align>
            <textcolor>FF999999</textcolor>
        </control>
        <!-- ** Required ** Do not change <id> or <type> (name of the used scraper and optionally the number of found lyrics) -->
        <control type="label" id="200">
            <visible>false</visible>
        </control>
    </controls>
</window>
Then browse to the addon folder of your kodi installation and then overwrite the existing file in the 1080i folder of the addon.
(For example the path of my kodi installation: /storage/.kodi/addons/script.cu.lrclyrics/resources/skins/Default/1080i )
And then maybe it looks like mine. 😀
Only problem is the file will get overwritten when the lyrics addon gets an update.
So you have to copy the created file again after updating. 😔
ImageLooks like this:
(2018-10-07, 21:02)peat Wrote: [ -> ]You can create a custom script-cu-lrclyrics-main.xml with the following content:
We prefer that you use a pastebin website for such longer contents in future cases.
(2018-10-07, 21:14)Klojum Wrote: [ -> ]
Sorry, will do next time. 🙄
Hi @peat
I have been meaning to Thank You for the entire summer  Big Grin (summer in Australia)
I have been using your code and works perfectly.  I think this should be added to the apps code.
The only thing that would make it even better would be for the black background of the song text to have a transparency so you can see the fan art
Or have the fan art as the background of the song text.
Thanks again for posting your code
