Hello all,
I'm new here and pretty much new to Kodi as well.
Not a complete n00b but you know... ;-)
I'm using LibreElec on an Odroid-C2 with an eMMC module.
x264 mkv and x265-hevc works flawlessly, which is great.
But I noticed some stuttering when playing a DVD (VIDEO_TS folder with VOB files).
All is streamed from my Synology NAS through samba sharing.
Any one have an idea why?
Sorry - we did not make the build you are running. The code that you use is not even on github.com/xbmc - please ask with your distribution.
Pls. provide a complete kodi debug log file with component logging enabled.
Select only "Video" in the list of components do debug.
The version of LE and the originator of the LE build would be helpful too
(2017-02-10, 13:09)fritsch Wrote: [ -> ]Sorry - we did not make the build you are running. The code that you use is not even on github.com/xbmc - please ask with your distribution.
I'm sorry, I was not aware that asking about Libreelec was not allowed in here.
It runs Kodi after all...
(2017-02-10, 13:10)peak3d Wrote: [ -> ]Pls. provide a complete kodi debug log file with component logging enabled.
I will try to grab those in the weekend. Cheers
(2017-02-10, 13:56)Panja0 Wrote: [ -> ] (2017-02-10, 13:09)fritsch Wrote: [ -> ]Sorry - we did not make the build you are running. The code that you use is not even on github.com/xbmc - please ask with your distribution.
That's the problem it does NOT run kodi. It runs kodi + some thousand lines of custom code and therefore support, especially for everything not x86 is very hard ...
Ok, my bad.
Did not know that.
I though it was "just" a custom linux distro running Kodi on top of it.
You can ask about LE on this forum, you just need to ask in the right section of the forum to receive the support. Just make sure you provide a log file as peak3d stated above.
