Hello,
I use the renamoer otption to directory and have so:
$T ($Y) { [$K] }
When I have a label called V.O. and rename the folder donĀ“t writhe the last "." only export "V.O"
I think is a bug.
Thanks in advance.
Correct.
We have a dedicated check for that and filter that away on purpose :p
Can't remember why... so we might change that in one of the next versions.
that is because otherwise you would get a movie like:
Title (2016) V.O..avi
we suppress double dots at the end
(2017-02-12, 19:12)mlaggner Wrote: [ -> ]that is because otherwise you would get a movie like:
I refer to the renamed directory at this time so it has no extension, besides I use [ ]
there are the same rules for folder names..
but we're planning a rework of the renamer an may take that into account
ok, i did a quickfix to only replace these double dots when renaming a file, but not directory...
