Full Version: Artist Slideshow Not Starting
I've been on the Artist Slideshow forum and I was referred to this forum.
I've been using KODI (Windows) since Eden. AS and Transparency always worked fine. With Jarvis, AS developed a problem, which has carried over into Krypton.
I launch KODI and go to Music. When a song starts to play, I go to the playback window and all I get is a static background. I open the Visualizations window, and AS is enabled, but it's not displaying any images.
If I disable AS at that point, save the settings, then re-enable it, the problem is fixed and AS works properly until I exit KODI. When I restart KODI I need to repeat the procedure.
At the AS forum, they've examined my logs and apparently AS is starting normally. Any suggestions?
thanx for the report! will be fixed in the next version.
https://github.com/ronie/skin.transparen...20a16e38R4
(2017-02-11, 15:49)ronie Wrote: [ -> ]thanx for the report! will be fixed in the next version.
