Jep your mesa is too old. As you seem to like outdated distributions, you can use the wsnipex mesa ppa back from this time.
sudo add-apt-repository ppa:wsnipex/mesa
sudo apt-get update
sudo apt-get dist-upgrade
Thanks, that did the trick. Mesa updated and VAAPI working fine.
ps.: I've a lot of things installed and working fine inside this nuc. I'm afraid some of them stop working if I upgrade to 16.04.
I took a swing at updating Kodibuntu 14.04 to 16.04. Amazingly it worked just fine. (Mind you, I only run Kodi) Of course, you'll want to update your Kodi/mesa/vaapi ppa to point to xenial instead of trusty. You might also want to clone your 14.04 before attempting the upgrade, just in case.
It's probably better to install 16.04 from the ground up, though..
Installed the latest mesa ppa but still getting the following error
09:49:01.548 T:139986085365504 ERROR: VAAPI::GLUnMapSurface - Error: the requested function is not implemented(20)
09:49:01.549 T:139986085365504 ERROR: VAAPI::GLMapSurface - Error: the requested function is not implemented(20)
09:49:01.584 T:139986085365504 ERROR: VAAPI::GLUnMapSurface - Error: the requested function is not implemented(20)
09:49:01.584 T:139986085365504 ERROR: VAAPI::GLMapSurface - Error: the requested function is not implemented(20)
09:49:01.650 T:139986085365504 ERROR: VAAPI::GLUnMapSurface - Error: the requested function is not implemented(20)
09:49:01.651 T:139986085365504 ERROR: VAAPI::GLMapSurface - Error: the requested function is not implemented(20)
Running Kodibuntu
Linux kodi-HTPC 3.13.0-108-generic , Ubuntu Trusty
Guessing my base OS is too old?
Quote:09:40:35.453 T:139989804496896 NOTICE: GL_RENDERER = Mesa DRI Intel® Ironlake Desktop
09:40:35.453 T:139989804496896 NOTICE: GL_VERSION = 2.1 Mesa 10.6.6
Follow the above post.
I don't understand. I installed the latest version (10.6.6.) available in the wsnipex mesa ppa. What else?
What does: vainfo state?
It seems your VAAPI implementation, including mesa driver level is too old. That won't wor anymore. You can disable VAAPI entirely then.
(2017-02-12, 14:40)fritsch Wrote: [ -> ]What does: vainfo state?
libva info: VA-API version 0.38.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_35
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.38 (libva 1.6.0.pre1)
vainfo: Driver version: Intel i965 driver - 1.3.0
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264Main : VAEntrypointVLD
VAProfileH264High : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
Will an upgrade to 16.04 resolve this?
Ouh 1.3.0!
Try adding wsnipex vaapi ppa, too and retry.
Thx
for this post, i have the same issue on ubuntu 14.04.
wsnipex vaapi ppa solved this issue.
sudo -i
add-apt-repository ppa:wsnipex/vaapi
apt-get install intel-vaapi-driver
or in one line :
sudo add-apt-repository ppa:wsnipex/vaapi && sudo apt-get update && sudo apt-get upgrade
thx again
(2017-02-12, 15:11)fritsch Wrote: [ -> ]Ouh 1.3.0!
Thanks fritsch. That fixed it.
Hi, I am running mythbuntu 14.04. Tried following the various suggestions on this thread, including adding both repositories and doing an apt-get update and an apt-get dist-upgrade. No joy.
Here is the message I get:when I try to play an mpeg2 720p recording with vaapi enabled for mpeg2:
ERROR: failed to import VA buffer NV12 into EGL image: 12292
kodi.log can be found here -
http://filebin.ca/3GqDUsc1XViJ
vainfo:
libva info: VA-API version 0.39.2
libva info: Found init function __vaDriverInit_0_38
vainfo: VA-API version: 0.39 (libva 1.7.1)
vainfo: Driver version: Intel i965 driver for Intel(R) Haswell Mobile - 1.6.1.pre1 (1.6.1.pre1)
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileJPEGBaseline : VAEntrypointVLD
When I try
sudo apt-get install intel-vaapi-driver
I get the following:
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package intel-vaapi-driver
Any assistance would be greatly appreciated!
Marc
