(2017-09-24, 20:45)MrSeb Wrote: [ -> ]Bonjour Guilouz,
Bravo pour ton thème ! Comment gères-tu les sagas sur ton thème ? Utilises-tu un programme adéquate ? As-tu un dossier pour les logos, fanarts... où tu les places dans le dossier de la saga ?
Désolé, je suis un néophyte...
Merci pour tes réponses.
Hello Guilouz,
Congratulations on your theme! How do you manage the sagas on your theme? Are you using an adequate program? Do you have a folder for logos, fanarts ... where do you put them in the saga folder?
Sorry, I'm a neophyte ...
Thank you for your answers.
Gracus replied to my place ^^
You can also use Movie Set Artwork Automator addon do add artworks in database (
https://forum.kodi.tv/showthread.php?tid=153502)
Sorry for being a pain in the ass, but I noticed that with the new PVR radio updates the visualisation isn't displayed anymore in fullscreen radio.
Samples: before update, after update without changing anything.
watch gallery
BTW: the visualisation is shown oke when the OSD is visible.
(2017-09-24, 23:37)rudrood Wrote: [ -> ]Sorry for being a pain in the ass, but I noticed that with the new PVR radio updates the visualisation isn't displayed anymore in fullscreen radio.
watch gallery
Yes that happen when a fanart is visible and setting 'Hide fanart opacity in fullscreen mode' is enable because visualisation is behind background (background is a bit transparent when this setting is disable).
I have added a setting to choose if visualisation must be behind background or not.
Some PVR timeshift issues:
Plot and art don't move up on OSD and Info screen when in timeshift.
watch gallery
(2017-09-25, 02:35)rudrood Wrote: [ -> ]Some PVR timeshift issues:
watch gallery
Can you try last git please ?
Just a heads up for those using Kodi 18 64bits for windows
inputstream adaptative has been added back since a few nightlies so youtube addon (and other similar addons) should now work without issue
Pillow has finally been added back in today's nightly so extended info (and probably other addons depending on pillow) now works as intended instead of giving an error message
(2017-09-25, 15:18)Gracus Wrote: [ -> ]Just a heads up for those using Kodi 18 64bits for windows
Ext info back : great news. Tnx. And it's working indeed. This makes my day.
(2017-09-25, 07:07)Guilouz Wrote: [ -> ] (2017-09-25, 02:35)rudrood Wrote: [ -> ]Some PVR timeshift issues:
watch gallery
Plot and art via OSD submenu "plot" is oke now (image 1), but on info (i key) the plot is still not shifted but the art is oke (image 2).
watch gallery
(2017-09-25, 23:29)rudrood Wrote: [ -> ] (2017-09-25, 07:07)Guilouz Wrote: [ -> ] (2017-09-25, 02:35)rudrood Wrote: [ -> ]Some PVR timeshift issues:
watch gallery
watch gallery
Missing this textbox. Fixed now.
Everything oke now, thanks!
New Update 2.7.9 on repository :
• Add possibility to show visualisation effects behind background
Enabled
Disabled
• Improvements
• Fix missing 'Jump to letter' functionality for some views
• Fix pause video during access to extended info with TV Shows
• Fix on PVR Radio
• Minor fixes
Finally the forum is back online. I'm now on 2.8.1. Thanks for the last updates. Great skin.
New Update 2.7.10 on repository :
• KODI 18 : RetroPlayer: Add renderer for Windows, OpenGL and OpenGLES
• Add possibility to use small video OSD
• Improvements
• Minor fixes
New Update 2.8.0 on repository :
• KODI 18 : Add Volume setting to Game OSD
• Improvements
• Minor fixes
