(2017-10-20, 20:25)Guilouz Wrote: [ -> ]Normally there is no difference between different OSs but you are two to have this same issue with a RaspberryPi. Working on OSX, Windows and LibreELEC Generic builds so not a skin issue.
FYI:
I have created a post in the skinshortcuts-Thread:
https://forum.kodi.tv/showthread.php?tid...pid2657452
Maybe one of the coders can help out or has a clue whats going wrong
(2017-10-21, 10:06)hansmilhouse Wrote: [ -> ]I'm new here and I tried looking for the answer to this issue, but I couldn't find anything. I have Kodi 18 with this mod installed on my windows pc and an Ubuntu home theater pc. On my windows pc the runtime and time of completion appear as pictured, but on the Ubuntu pc both of those are blank. Could anyone help me figure out why?
I dont' see... Runtime and time of completion are provided by Kodi (not by an addon). It's working on LibreELEC (Linux distribution). What build do you use ?
(2017-10-21, 10:10)Solo0815 Wrote: [ -> ] (2017-10-20, 20:25)Guilouz Wrote: [ -> ]Normally there is no difference between different OSs but you are two to have this same issue with a RaspberryPi. Working on OSX, Windows and LibreELEC Generic builds so not a skin issue.
FYI:
I have created a post in the skinshortcuts-Thread: https://forum.kodi.tv/showthread.php?tid...pid2657452
It's possible it's Kodi build for RPi have an issue too.
(2017-10-21, 13:32)Guilouz Wrote: [ -> ] (2017-10-21, 10:06)hansmilhouse Wrote: [ -> ]I'm new here and I tried looking for the answer to this issue, but I couldn't find anything. I have Kodi 18 with this mod installed on my windows pc and an Ubuntu home theater pc. On my windows pc the runtime and time of completion appear as pictured, but on the Ubuntu pc both of those are blank. Could anyone help me figure out why?
I think there's a problem with my system. I'm using
18.0+git20171022.0201-d68e7e3
on
Ubuntu 17.10 (kernel: Linux 4.13.0-16-generic)
but in Kodi it shows up as
18.0-ALPHA1 Git:20121104-d68e7e3 - Nov 4 2012
try yesterday this mod with LibreELEC 9 (alpha)
[good] fast on my PI 3, faster as v1 (Kodi 17)
[bad] no EPG Widget for Live-TV (as in v1 for Kodi 17)
[bad] no logoff possible (need this for my profiles), default Estuary has not this problem
(2017-10-22, 08:23)noxx2 Wrote: [ -> ]try yesterday this mod with LibreELEC 9 (alpha)
What do you mean by EPG widget ?
Logon/logoff fixed on last git.
(2017-10-16, 20:32)Guilouz Wrote: [ -> ] (2017-10-15, 15:33)lepoilu Wrote: [ -> ]Hello,
I would like to know if it is possible to add a function which at the start of a video would display the OSD menu for a few seconds, for a fixed duration or of choice (0, 1, 2, 5 seconds etc.).
Also if it is possible to add or if a script already exists, a button that would show the associated saga in the poster of a movie.
Thank you.
elchupete: 3D
Yes there are still a few worries in alpha.
On the other hand it is enough to display the OSD menu and to select 3D (glasses) and to deactivate/activate and it is good ...
No, no need to add this. If you want OSD just use remote/keyboard buttons.
Not possible to do that, except if marcelveldt add this functionnality.
Thank you for this clear answer.
Using estuary mod v2 i have created a new menu item which points to a favourite which is a folder with 3D movies. What widget do I use to show posters of these specific movies on the main screen?
(2017-10-24, 00:39)viperlogic Wrote: [ -> ]Using estuary mod v2 i have created a new menu item which points to a favourite which is a folder with 3D movies. What widget do I use to show posters of these specific movies on the main screen?
You must create a smartplaylist who is pointing to your folder and select this smartplaylist as widget.
See my post here :
https://forum.kodi.tv/showthread.php?tid...pid2633661
hey,
i came across a weird behaviour, when i have a widget item that opens a window direcly, say youtube settings(or some search screen), when i back out of it it will loop, meaning it will reload the screen multiple time and i have to back out of it 2 or 3 times.
so i basicly have youtube as a widget so it shows all the youtube "folders" or categories,
skin estuary mod v2 2.8.3
kodi 18.0-ALPHA1 git20171021
(2017-10-25, 17:04)davidx Wrote: [ -> ]hey,
Can't help you for that. Keep in mind that kodi 18 and addons are in developement and not fully compatible yet.
