(2017-11-05, 18:35)tehax Wrote: [ -> ] (2017-11-05, 17:42)Guilouz Wrote: [ -> ] (2017-11-05, 16:02)tehax Wrote: [ -> ]Hm, in non of media information "i" windows like pvr, series or movies can i see this fsk info or logo. Imho it will be a good additional info to see it. What do you think about my suggest to add the channel no. In pvr information window?
Not really understand what you mean...
I mean the red marking in the screenshot from estuary.
PS: How can i add a picture viewable into a post?
There is already this info when switching channels :
But I have added channel number on info dialog too :
(2017-11-05, 19:23)Solo0815 Wrote: [ -> ] (2017-10-27, 17:09)Solo0815 Wrote: [ -> ]caretaker discussion:
If there is only a popup, then I can live with that, but please don't unload your skin, if a blacklisted addon/repo is found.
Who is deciding which repos/addons should be blacklisted?
obsolete
bug report/feature request: (don't know, if this is a bug or FR)
If I highlight an item on the Live-TV widget, e.g. "Last played channels" then the clearlogo/clearart at the top and fanart in the BG for this item is shown.
If press "Info" on that item, PVRInfo opens, but there is no clearart, -logo or Fanart-BG
Please add/fix it
Thx
@guilouz:
Maybe you have overseen that during all the caretakter-discussion?
Can't test this issue I have no PVR backend, I only use PVR Simple Client and I have no arts with that.
(2017-11-05, 19:25)hellwich Wrote: [ -> ] (2017-11-05, 14:37)Guilouz Wrote: [ -> ] (2017-11-05, 03:15)benrita Wrote: [ -> ]Thank you.
After scanning with Artwork Beef if it does not find disc art it shows just a blank blue disc on some movies but not on others that do not have disc art, weird.
Does this mean I can delete all extrafanart folders to free up hdd space ?
(2017-11-05, 13:40)hellwich Wrote: [ -> ]I'm unfortunately experiencing the same issue.
I'm using back button on the remote of NVIDIA Shield TV. Latest nightly.
/edit
Thanks for the skin Guilouz. Good work, really loving it!
Yes you can delete extrafanarts folders.
It's normal, it take few minutes, time that kodi cache artworks.
I believe you misquoted me. I'm not talking about artwork, I'm talking about the sidebar menu which pops up when going back to the main menu from (e.g.) EPG or recordings menu.
Ah that ^^ It's not an issue, it's voluntary because when you are on channel list and enter in PVR guide or PVR recordings and go back, kodi doesn't return to channels list.
(2017-11-05, 19:54)Perlbo Wrote: [ -> ] (2017-11-05, 14:40)Guilouz Wrote: [ -> ] (2017-11-05, 11:44)Perlbo Wrote: [ -> ]HI Guilouz,
is it possible to add FSK Logo or other method that shows it ? (Film age rating (German) ?
https://www.spio-fsk.de/?seitid=508&tid=72
No, no logo for that, there is already this info on dialog info window.
Ups...really ? that would be nice and is enough for me. On first look i don't see this info ... :-(
You can see it here, it's MPAA :
(2017-11-05, 17:40)Guilouz Wrote: [ -> ] (2017-11-05, 15:30)estuary_enthusiast Wrote: [ -> ]Hi. Can we change the speed of fanart change? I want to speedup the cycle
No, not possible without editing code.
What file to edit? And can you add an option later?
How can I Add Categories like this image? and the marked as watched?
thanks
(2017-11-06, 02:10)estuary_enthusiast Wrote: [ -> ] (2017-11-05, 17:40)Guilouz Wrote: [ -> ] (2017-11-05, 15:30)estuary_enthusiast Wrote: [ -> ]Hi. Can we change the speed of fanart change? I want to speedup the cycle
No, no option for that.
In Includes.xml, variable 'DefaultBackground', replace <timeperimage>3000</timeperimage> in multiimage control.
(2017-11-06, 02:35)attackkkkkk Wrote: [ -> ]How can I Add Categories like this image? and the marked as watched?
thanks
This is categories by default, nothing to do to have that. If you mean small categories, there is a setting in skin settings for that.
Marked as watched icon is automatically shown when item is watched.
(2017-11-06, 03:36)Guilouz Wrote: [ -> ] (2017-11-06, 02:10)estuary_enthusiast Wrote: [ -> ] (2017-11-05, 17:40)Guilouz Wrote: [ -> ]No, not possible without editing code.
Thanks. And for the widget?
@ guilouz:
Please change line nr. 26 in
DialogPVRInfo to
<texture fallback="DefaultTVShows.png">$VAR[PVRArtworksVar]</texture>
for the Poster of the recorded show
and line 4 to
<onload>SetProperty(infobackground,$ESCINFO[Window(Home).Property(SkinHelper.ListItem.Art.Fanart)],home)</onload>
for Fanart. I couldn't get "ExtraFanart" to work. Maybe you can do that?
I'll try more changes for PVR next weekend.
I suddenly find that it now takes a full 5 minutes to start Kodi. I am running windows 10 on an i7 with and ssd drive.
The only change I have made was upgrading the skin to current version (2.8.7), so I think it may be related to that change.
Prior to this update running previous version of the skin, startup would take about 15 seconds.
When checking the log I notice several
hundred lines that I have not seen before and I think they may be responsible for the delay.
They read and repeat:
11:59:30.909 T:9848 ERROR: NEWADDON Unknown Video Info Key "progress"
11:59:30.909 T:10620 WARNING: Invalid media type "genre"
11:59:30.909 T:10620 ERROR: NEWADDON Unknown Video Info Key "progress"
11:59:30.909 T:10712 WARNING: Invalid media type "genre"
11:59:30.909 T:10712 ERROR: NEWADDON Unknown Video Info Key "progress"
11:59:30.910 T:6268 WARNING: Invalid media type "genre"
11:59:30.910 T:6268 ERROR: NEWADDON Unknown Video Info Key "progress"
11:59:30.910 T:10620 WARNING: Invalid media type "genre"
11:59:30.910 T:10620 ERROR: NEWADDON Unknown Video Info Key "progress"
11:59:30.910 T:10712 WARNING: Invalid media type "genre"
11:59:30.910 T:10712 ERROR: NEWADDON Unknown Video Info Key "progress"
Can you advise me if this might be related to the updated skin or the new addons that accompany it (
artwork beef and artwork helper) which I also installed with the new version of the skin.
When it eventually starts, Kodi works fine,
Any advice would be appreciated.
Thank you
(2017-11-06, 03:38)Guilouz Wrote: [ -> ] (2017-11-06, 02:35)attackkkkkk Wrote: [ -> ]How can I Add Categories like this image? and the marked as watched?
thanks
I press marked as watched and it does not work :/
(2017-11-06, 15:00)estuary_enthusiast Wrote: [ -> ] (2017-11-06, 03:36)Guilouz Wrote: [ -> ] (2017-11-06, 02:10)estuary_enthusiast Wrote: [ -> ]What file to edit? And can you add an option later?
Lines 41, 56 and 72 in Home.xml
(2017-11-06, 18:30)Solo0815 Wrote: [ -> ]@ guilouz:
Please change line nr. 26 in DialogPVRInfo to
and line 4 to
Added for next release. Difficult to try without me being able to test...
Can you try with this line :
<value condition="Skin.HasSetting(SkinHelper.EnableExtraFanart) + Container.Content(livetv) + !String.IsEmpty(Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt))">$INFO[Window(Home).Property(SkinHelper.ListItem.Art.ExtraFanArt)]</value>
In Variables.xml after line 3374
(2017-11-06, 19:15)doktourtv Wrote: [ -> ]I suddenly find that it now takes a full 5 minutes to start Kodi. I am running windows 10 on an i7 with and ssd drive.
When checking the log I notice several hundred lines that I have not seen before and I think they may be responsible for the delay.
Can you advise me if this might be related to the updated skin or the new addons that accompany it (artwork beef and artwork helper) which I also installed with the new version of the skin.
Thank you
This errors have nothing to do with that. They are there from the beginning and dont' worry about that, progress error are from widgets don't have progress status ans genre warning is about genre widget from Skin Helper.
My Kodi start and load my library in few second, nothing to see with latest version.
A full debug load can be help.
