(2017-11-19, 05:22)terpsarlington Wrote: [ -> ]i was trying to do a Genres widget appearance that look likes the default Genre widget in movies and TV. where you have three posters with banner. However when ever i choose appearence as genres i just get "tow laughing faces" with banner on the bottom. anyway to change this into the three posters.
windows 10, 64 bit.
You must select genres from Skin Helper Service widgets if you want the same as default widgets.
(2017-11-19, 06:32)mi3ns Wrote: [ -> ]when we will get the new update (2.8.9) ?
and thank you for keeping up the good work I appreciate what you are doing
You can download it on last git.
I reset the settings to default for Media/Music and restarted Kodi and it got sorted out somehow.
Estuary MOD V2 working great here, thanks! I am just looking for a way to enter the API keys without trying to remember (or writing down, yuck!
) endless rows of numbers and digits. Copy and Paste is not available, because Kodi runs on Libreelec.
I have looked in the userdata settings.xml but there are no mentions of API keys. They must be saved somewhere, but where? Help!
(2017-11-19, 17:36)mozomo Wrote: [ -> ]Estuary MOD V2 working great here, thanks! I am just looking for a way to enter the API keys without trying to remember (or writing down, yuck! ) endless rows of numbers and digits. Copy and Paste is not available, because Kodi runs on Libreelec.
For Skin Helper Service in script.module.metadatautils folder in your userdata.
(2017-11-19, 15:23)Guilouz Wrote: [ -> ] (2017-11-19, 05:22)terpsarlington Wrote: [ -> ]i was trying to do a Genres widget appearance that look likes the default Genre widget in movies and TV. where you have three posters with banner. However when ever i choose appearence as genres i just get "tow laughing faces" with banner on the bottom. anyway to change this into the three posters.
windows 10, 64 bit.
wow you have thought of everything.
FR:
1. Please add
xml:
<shadowcolor>text_shadow</shadowcolor>
to all label-controls which have
xml:
<texture colordiffuse="$VAR[GradientColorVar]">lists/focus-gradient.png</texture>
as BG. Then they are much easier to read, e.g. in MyPVRRecordings, MyPVRSearch etc. I looked especially for PVR.xmls
but maybe there are some others
2. If you want to change the color and "SH ColorPicker" is not installed, then open a window, where the user can choose to install it. Some may miss it and wonder why they can't change the color
3. add Option to choose the shadow color of the text. On my TV the font is much easier to read, if you change "text_shadow" to "ff000000" (black)
4. I polished "DialogPVRChannelGuide" a little bit and I hope you like it
changes:
- add SeasonNr, EpisodeNr and Episodename (only if at least one of them is available)
- added shadowcolor
https://pastebin.com/1Q1if0n4
(2017-11-20, 09:26)Solo0815 Wrote: [ -> ]FR:
1. Please add
xml:
xml:
as BG. Then they are much easier to read, e.g. in MyPVRRecordings, MyPVRSearch etc. I looked especially for PVR.xmls but maybe there are some others
changes:
- added shadowcolor
1-3. No, no shadow for lists and not possibility to change his color who does not look like me very useful.
2. List of necessary addons are in first page and in skin settings too. There is a popup when addons are not installed, I can't do more for that.
4. I have added this info for next release.
(2017-11-20, 13:34)Guilouz Wrote: [ -> ] (2017-11-20, 09:26)Solo0815 Wrote: [ -> ]FR:
1. Please add
xml:
xml:
1. Maybe you missunderstood something in 1. and 3. Let me try to explain this better.
In almost all label-controls in PVR*.xmls is
xml:
missing. The shadowcolor-tag is there for textlabels in all the other xmls. Please add this to the PVR-xmls also
Please compare:
View_50_List.xml
MyPVRRecordings.xml
I see no difference, why there shouldn't be a textshadow in PVRwindows
3. If I change the "text_shadow"-variable in "colors -> default.xml" to "ff000000" (black), then the text is IMHO better to read. That's why I asked to add this option. I have no problem, if I have to add another xml with default-colors and only the textshadow-variable is changed. Just thought, some users find it useful also
2. "ColorPicker" is displayed as an optional addon in Estuary -> SkinSettings. If ColorPicker is not installed, then IMHO the ColorPicker-button should be greyed out in Settings. The same for "SkinBackup" with SH-Backup-Plugin.
(2017-11-20, 18:17)Solo0815 Wrote: [ -> ] (2017-11-20, 13:34)Guilouz Wrote: [ -> ] (2017-11-20, 09:26)Solo0815 Wrote: [ -> ]FR:
1. Please add
xml:
xml:
In almost all label-controls in PVR*.xmls is xml:
Please compare:
View_50_List.xmlMyPVRRecordings.xml
I understand what you mean now, I have added missing shadow for PVR. Try if it's ok on last git.
to avoid this (banner over clearart)
