New Update 2.1.0 on repository :
• Add support for Skin Shortcuts addon to customize home menu and widgets
• Add support for thumbnails with NextUp Service addon
• Add support for Videolyrics v2 (thanks to manfeed)
• Minnor fixes
• Special Thanks to Gracus and ferent for reporting issue
Hurrah hurrah hurrah for Skin Shortcuts!
Thanks for the update!
And time for first bug reports on release 2.1.0
I use a mouse to control kodi and so I use right click to go back to home menu from library
I use infowall view ans so I put my mouse to the left part on the screen to make my right click without fearing to open a context menu
The issue is: if I had one of the TVshow or movie overed by the mouse right before reaching the left part of the screen (with TVshow/movie info displayed) as on this screenshot:
Then when I go back to library, the fanart of this TVshow/movie will be shown on the category selection panel:
(2017-03-04, 00:34)Gracus Wrote: [ -> ]Thanks for the update!
Just try I have not reproduce this issue.
I upload video on youtube to show you :
https://youtu.be/_J1lLUcNI5A
(2017-03-04, 01:59)Guilouz Wrote: [ -> ] (2017-03-04, 00:34)Gracus Wrote: [ -> ]Thanks for the update!
I upload video on youtube to show you : https://youtu.be/_J1lLUcNI5A
Because you return to the same library and so you now entering it without having to chose if you want genre, titles, ...
Try to go out from movies the way I explained then try to enter into TVshow to trigger the categories page before library
BTW I check on my girlfriend's computer and the issue was already there on 2.0.6
(2017-03-04, 03:17)Gracus Wrote: [ -> ] (2017-03-04, 01:59)Guilouz Wrote: [ -> ] (2017-03-04, 00:34)Gracus Wrote: [ -> ]Thanks for the update!
Yes, I have reproduce issue. Very strange. Dis you try with original Estuary ? My variable is the same.
EDIT : Can you try latest git. I think it's fixed.
Well that was the quickest Beta test ever!! I barely had a chance to test it... however, excellent job. The only issue I would mention, and this had been there before the beta, would it be possible to increase the size of "end time" box. If you don't use a 24 hour clock, the entry scrolls.
(2017-03-04, 03:56)Guilouz Wrote: [ -> ] (2017-03-04, 03:17)Gracus Wrote: [ -> ] (2017-03-04, 01:59)Guilouz Wrote: [ -> ]Just try I have not reproduce this issue.
Just try last git.
Issue gone but now there is another one: when you are in category page and overing the folder item with mouse, it appears as background too (Just this one but not the other choice on the same page)
And if you have time, take a look at the aspect/ratio code for infowall at episode level:
Seems a little bit wrong...
(2017-03-04, 04:35)Gracus Wrote: [ -> ] (2017-03-04, 03:56)Guilouz Wrote: [ -> ] (2017-03-04, 03:17)Gracus Wrote: [ -> ]Because you return to the same library and so you now entering it without having to chose if you want genre, titles, ...
Just try last git.
Take a look a last git, I have fixed this two issue.
(2017-03-03, 23:40)Guilouz Wrote: [ -> ]New Update 2.1.0 on repository :
Does not seem to work (or did I missanderstood this one)
It show landscape artwork and not thumbnail extract from the episode
(2017-03-04, 05:01)Guilouz Wrote: [ -> ] (2017-03-04, 04:35)Gracus Wrote: [ -> ] (2017-03-04, 03:56)Guilouz Wrote: [ -> ]Yes, I have reproduce issue. Very strange. Dis you try with original Estuary ? My variable is the same.
Just try last git.
Confirm it is fixed
Its broken for android, all I I see is the background, I tested on two devices, nvidia shield tv and sony tv
For some reason nothing happens when I click Add item under Customize main menu
