(2017-12-30, 14:03)ronvp Wrote: [ -> ] (2017-12-29, 20:30)Guilouz Wrote: [ -> ] (2017-12-29, 15:31)ronvp Wrote: [ -> ]
I found dialog-bg-nobo.png and increased transparency and tried many other different things, but it has no effect.
I do note that the file can only be found in the "AppData\Roaming\Kodi\addons\skin.estuary.modv2\themes\curial\dialogs" directory. is that the right one?
Figured it out, I needed to decompile the textures.xbt file, modify it and just recompile.. I will create a extra theme and share it here..
Noticed a small cosmetic bug, when in Shift view and each time when selecting a new movie, the clearlogo changes as it should, but then there is a short flash, like it is drawing it twice..
I am not sure if I need to post it here or in the Estuary forum, but is it possible that when in Live TV, Channel view (List), to not include the Channel number from Kodi. I am using the Zuki HDhomerun PVR client and have the "append channel number" option enabled. This is the only way to get the correct channel numbers to show up in the guide. But then in the Channel view, the channel numbers show up twice..
Guilouz,
Since Milhouse build 1228 the pvr endtime in OSD is Always the same as current time. Also the progressbar at the bottom is constant filled.
This also triggers nextup notification all the time.
Using TVHeadend (pvr.hts). In the Original Estaury skin it's oke.
See samples (first stock Estaury, second Estaury Mod 2).
http://imgur.com/gallery/NWfRv
N.B. Resolution for pvr is still shown as 3D.
Can provide you access to my TVHeadend server if needed.
(2017-12-30, 22:09)rudrood Wrote: [ -> ]@Guilouz,
Skins need to be adapted after
https://github.com/xbmc/xbmc/pull/13228
(2017-12-30, 16:54)ronvp Wrote: [ -> ]I am not sure if I need to post it here or in the Estuary forum, but is it possible that when in Live TV, Channel view (List), to not include the Channel number from Kodi. I am using the Zuki HDhomerun PVR client and have the "append channel number" option enabled. This is the only way to get the correct channel numbers to show up in the guide. But then in the Channel view, the channel numbers show up twice..
Instead of a workaround in the skin or somewhere else we should try to get the correct channel numbers in Kodi.
Are you using Kodi 17 or 18? If you are using 17, you could give 18 a try. Could make a difference.
Do you have the setting "use backend channel numbers" activated? If not, what happens if you activate it?
Have you tried the official hdhomerun pvr client? Never heard about "Zuki". Is this a fork?
(2017-12-31, 09:51)ksooo Wrote: [ -> ] (2017-12-30, 16:54)ronvp Wrote: [ -> ]I am not sure if I need to post it here or in the Estuary forum, but is it possible that when in Live TV, Channel view (List), to not include the Channel number from Kodi. I am using the Zuki HDhomerun PVR client and have the "append channel number" option enabled. This is the only way to get the correct channel numbers to show up in the guide. But then in the Channel view, the channel numbers show up twice..
In order:
I agree it should be fixed in Kodi and also Stock Kodi should show Channel Logo's in the guide grid and not under the guide.
I am using 18 (This was posted in the Esturay MOD V2)
Yes, I have those settings activated.
I have tried the official client that comes with Kodi. ZUKI is what is shown in the Logo of the HDHomerun client written by Michael Brehm. (Download via the silicondust HDHomerun)
This addon is giving additional options (More guide data and Channel numbers appended to the station name, etc..)
I have some problems about Estuary Mod V2. I loved that skin very much but when I select skin it crashes a few minutes later. I set up all required addons and files. Searched web but couldn't find anything that can help. In log file I see these lines before my Kodi crash:
00:09:19.752 T:1062204304 ERROR: NEWADDON Unknown Video Info Key "progress"
00:09:19.752 T:846332816 WARNING: Invalid media type "genre"
00:09:19.753 T:846332816 ERROR: NEWADDON Unknown Video Info Key "progress"
00:09:19.753 T:692056976 WARNING: Invalid media type "genre"
00:09:19.754 T:692056976 ERROR: NEWADDON Unknown Video Info Key "progress"
00:09:19.757 T:1062204304 WARNING: Invalid media type "genre"
00:09:19.757 T:1062204304 ERROR: NEWADDON Unknown Video Info Key "progress"
00:09:19.758 T:846332816 WARNING: Invalid media type "genre"
00:09:19.758 T:846332816 ERROR: NEWADDON Unknown Video Info Key "progress"
Then my free memory goes down rapidly and my kodi freezes. I have Librelec with Kodi 18 Alpha installed. (On Rasperry Pi 3)
Please help me to find the problem.. What am I missing ?
Hello LyNcHeR
That is not enough information. You will need to provide a
Debug_Log (wiki). The instructions are in my signature. Use the Basic method. Once you have
enabled debugging in Settings>System Settings>Logging,
restart Kodi then
replicate the problem. Once done
upload to pastebin and link back here.
(2017-12-30, 16:48)ronvp Wrote: [ -> ]Noticed a small cosmetic bug, when in Shift view and each time when selecting a new movie, the clearlogo changes as it should, but then there is a short flash, like it is drawing it twice..
I don't have this issue. Have you downloaded artworks with Artworks Beef ?
Yes send me access in PM, it it will help me a lot.
I will add recent PR changes from original Estuary soon, I have just returned to France.
Happy New Year !
(2018-01-03, 23:14)LyNcHeR Wrote: [ -> ]Hello,
Still crashes.
Here is my log as you describe.
https://paste.ubuntu.com/26315215/
The forum moderators have determined that banned addons (wiki) are present on your system. To receive assistance here, these banned items must be removed. If a clean log is not submitted within 3 days, then the relevant post(s) will be removed after this time.
Hello there
I am an absolute newbie in using different skins and cause of this, I have a few questions to this one. (native language german)
I have a Nvidia Shield TV 2015 since 2 years and used only SPMC on that. Now I wanted to see Kodi 17, ending in installing Kodi 18 and after some research this skin.
1. The universal movie scraper gives the option to show different ratings. First one is Imdb, but rotten tomatoes, metacritic and themoviedb is also selectable. But the other ratings will not be shown in the movie information. I found not one skin which is capable of doing this. Do I have to change settings? Other problem is, that I tested to check only imdb ratings and let all others unchecked, but this skin shows 2 Ratings: The first one is actually not the rating but the "Rated x/y" number and the second one is the rating of Themoviedb... But i only checked the IMDB Rating box... Is this a bug?
2. My TV Series shows the pictures of the actors (TVDB scraper), my movies dont... Is there also a setting I missed?
(2018-01-04, 12:36)Anshelmo Wrote: [ -> ]Hello there
1. Ratings on posters are provided from your scrapper and ratings in info window are from Skin Helper Service, ratings from TMDB and IMDB only.
2. Strange. Have you try to use another scrapper for your movies ?
