(2018-04-05, 12:00)Mario S. Wrote: [ -> ]Are music extrafanarts in music viz. not supported?
Great skin
Off course they are supported, you need to use Artwork Beef to download them.
Yes I know that already downloaded all music artwork with artwork beef.
in the album and song views I have extrafanart.
But not in the music viz.
There I have every time only one fanart I've one exists.
After updating my movies with Artwork Beef all my movies are displaying the same picture for the background FANART,cansome help on how to fix that?
(2018-04-05, 20:07)movie78 Wrote: [ -> ]After updating my movies with Artwork Beef all my movies are displaying the same picture for the background FANART,cansome help on how to fix that?
Have you tried a restart?
(2018-04-05, 20:33)Mario S. Wrote: [ -> ] (2018-04-05, 20:07)movie78 Wrote: [ -> ]After updating my movies with Artwork Beef all my movies are displaying the same picture for the background FANART,cansome help on how to fix that?
Yes, I did.
Strange, all my movies FANART background are displaying the same picture ( James Bond 007 Spectre movie fanart)
In Artwork Beef all settings vor mobiles are right?
Did you use local Files ?
(2018-04-05, 21:07)Mario S. Wrote: [ -> ]In Artwork Beef all settings vor mobiles are right?
In Artwork Beef all settings vor mobiles are right?Sorry what is VOR Mobiles?
Did you use local Files ?No
(2018-04-05, 16:38)Mario S. Wrote: [ -> ]Yes I know that already downloaded all music artwork with artwork beef.
Have you enable them in skin settings / Music OSD ?
(2018-04-05, 20:45)movie78 Wrote: [ -> ] (2018-04-05, 20:33)Mario S. Wrote: [ -> ] (2018-04-05, 20:07)movie78 Wrote: [ -> ]After updating my movies with Artwork Beef all my movies are displaying the same picture for the background FANART,cansome help on how to fix that?
Yes, I did.
Have you try to use Artwork Beef setting to delete a specify type of artworks (here fanarts) ? You will have most help in Artwork Beef thread.
(2018-04-06, 02:29)Guilouz Wrote: [ -> ] (2018-04-05, 20:45)movie78 Wrote: [ -> ] (2018-04-05, 20:33)Mario S. Wrote: [ -> ] Have you tried a restart?
Yes, I did.
Found out that there is no FANART in the downloaded Artwork Beef folder.
Sorry, going to post on the Artwork Beef Forum.
Yes, I did.
Sorry But you the only Developer I see online,quick question how does Artwork Beef store the downloaded art on your system?
(2018-04-06, 02:25)Guilouz Wrote: [ -> ] (2018-04-05, 16:38)Mario S. Wrote: [ -> ]Yes I know that already downloaded all music artwork with artwork beef.
Hmm must have a look :O
Only setting I know I made was in the music viz setting use fanart.
Is there one more in the skin settings menu??
Edit:
I found it sorry for my misstake and thanks for your Help.
