(2018-05-20, 22:43)Guilouz Wrote: [ -> ][NEGATIVE SQUARED LATIN CAPITAL LETTER B]New Update 2.9.9 on repository :[/B]
• KODI 18 : Allow user to select resolutions
• Add video fps flag icon on OSD
• Changes in playing trailers on video info (Thanks to jurialmunkey)
• Fix music themes with video addons
• Minor fixes
After updating to this version with the latest Kodi 18 nightlies on my Nvidia Shield Android TV, the Kodi crashes frequently. Changing the skin to another one it doesn't crash.
(2018-05-25, 06:21)cooler Wrote: [ -> ]Hi.
I don't see download subtitles flag on OSD, on updated to 2.9.9 how Can I get it back?
Also how do I get date under the time, at the top?
Both have gone missing on update.
You can find it here :
For the date, there has never been on my mod.
(2018-05-25, 10:01)iMak Wrote: [ -> ] (2018-05-20, 22:43)Guilouz Wrote: [ -> ][NEGATIVE SQUARED LATIN CAPITAL LETTER B]New Update 2.9.9 on repository :[/B]
• Minor fixes
Have you enable theme.mp3 setting ?
I recently noticed that there is a problem with this feature when the theme.mp3 file is not present. I think to remove this feature.
(2018-05-25, 12:33)Guilouz Wrote: [ -> ] (2018-05-25, 10:01)iMak Wrote: [ -> ] (2018-05-20, 22:43)Guilouz Wrote: [ -> ][emoji743]New Update 2.9.9 on repository :[/B]
• Minor fixes
It was Enabled by default, I disabled it and no more crashes. Thanks for the tip.
(2018-05-25, 13:31)iMak Wrote: [ -> ] (2018-05-25, 12:33)Guilouz Wrote: [ -> ] (2018-05-25, 10:01)iMak Wrote: [ -> ]After updating to this version with the latest Kodi 18 nightlies on my Nvidia Shield Android TV, the Kodi crashes frequently. Changing the skin to another one it doesn't crash.
Thanks for your return, I have removed this feature on last git.
(2018-05-25, 12:32)Guilouz Wrote: [ -> ] (2018-05-25, 06:21)cooler Wrote: [ -> ]Hi.
Thanks for that, but this is what I have and no option to download.
(2018-05-25, 18:53)cooler Wrote: [ -> ] (2018-05-25, 12:32)Guilouz Wrote: [ -> ] (2018-05-25, 06:21)cooler Wrote: [ -> ]Hi.
What Kodi build do you use? I think you don't have latest nightly build.
(2018-05-25, 14:04)Guilouz Wrote: [ -> ] (2018-05-25, 13:31)iMak Wrote: [ -> ] (2018-05-25, 12:33)Guilouz Wrote: [ -> ] Have you enable theme.mp3 setting ?
I had the same issue. As soon as I opened up the Movies or TV shows list, it crashed. Just disabled the option and now no more crashes.
Thanks a lot.
Yes your right am using the Kodi 18.0-ALPHA1 Git:20171103.
(2018-05-24, 01:21)Guilouz Wrote: [ -> ] (2018-05-24, 00:59)AshG Wrote: [ -> ] (2018-05-22, 20:04)schumi2004 Wrote: [ -> ] I was searching for this also and couldn't find it in this thread so I modified the Fonts.xml a bit.
I increased the font size for all items with 10, maybe it's usefull for some of us.
Just replace files in skin folder.
Download en overwrite files in language and xml folder
Thanks - This really helped me, i found myself continually squinting, no fault of this skin, just pour eyesight!
Be careful about this font size, fonts are not adapted on all screens.
yeah thanks, I noticed that, I will see if i can play around and make some improvements...
If i was to go through and optimize the pages for both sets of fonts, would you except PRs (if i broke them down into smaller chunks) ? i'm happy to do the work (i don't think it will be too intrusive?). As the other alternative is to mod your mod and try and keep it in sync - which i don't fancy my chances!
Hey Guilouz,
I am using your Mod version of Estuary as a basis for my own little modding (just a few thing to my personal likings.
As I am using the Music library quite often, I noticed that there seems to be a bug, that the Fallback Default Icons for textures like DefaultAudio.png etc. pp. will be visible for a split second, even if the media has a download Cover.
I already posted it in the Bug thread, but its seems not much followed by the developers, so maybe you have a clue whats causing this behaviour.
https://forum.kodi.tv/showthread.php?tid...pid2738206
Thanks for your time and work
(2018-05-28, 17:37)sonic00 Wrote: [ -> ]Hey Guilouz,
It's not a bug, fallback are shown during textures are loaded or if artworks are not found, it's depending of your hardware, on my two machines, I never see them, textures are instantly loaded.
(2018-05-27, 11:41)AshG Wrote: [ -> ] (2018-05-24, 01:21)Guilouz Wrote: [ -> ] (2018-05-24, 00:59)AshG Wrote: [ -> ]Thanks - This really helped me, i found myself continually squinting, no fault of this skin, just pour eyesight!
You can make a PR on github and I will accept it if it's complete and without issue.
(2018-05-28, 18:15)Guilouz Wrote: [ -> ] It's not a bug, fallback are shown during textures are loaded or if artworks are not found, it's depending of your hardware, on my two machines, I never see them, textures are instantly loaded.
Thx for the quick reply, much appreciate it. Ok, if the fallback textues are always shown before the actual Artwork is loaded it makes sense. I only use a RPi2 as hardware so its not the most powerfull device, that could explain why I see the fallback textures it for a split second, but its strange because I never notice this behaviour on the Video Library, but its quite noticeable on the Music Library (and Video posters are usual a bit larger than Music covers).
But again, thank you very much for the clarification. Have a nice day/night
(2018-05-28, 18:16)Guilouz Wrote: [ -> ] (2018-05-27, 11:41)AshG Wrote: [ -> ] (2018-05-24, 01:21)Guilouz Wrote: [ -> ]Be careful about this font size, fonts are not adapted on all screens.
Fair enough, give me some time and i shall
