(2017-03-19, 04:24)muza Wrote: [ -> ]hello, disable sub menu not working for me either, all addons up to date, thanks
Yes it is odd, have everything up to date but cannot seem to switch off the submenu with personalized widgets either.
(2017-03-19, 04:53)mack4999 Wrote: [ -> ] (2017-03-19, 04:24)muza Wrote: [ -> ]hello, disable sub menu not working for me either, all addons up to date, thanks
Make sure you have latest Skin Shortcuts from master branch on github. This setting is from Skin Shortcuts.
Hi, i know it's not mod problem..
Why every time I resume x265 file, it's crash? any idea?
hello, still not working with skin shortcuts updated from github, i'll try a clean install, thanks
Guilouz
Salut
Thank you for the library info. update. Love it, all the library stats that I wanted are there!
hey i want to update the skin but i get an update failed
why ?? i also try to deavticate an use the standart skin then check update but i geht same notice update failed
also my addons want update automaticaly but under settings addon i have it marked to automatic update
The solution is a few posts back, twice.
(2017-03-19, 05:33)Guilouz Wrote: [ -> ] (2017-03-19, 04:53)mack4999 Wrote: [ -> ] (2017-03-19, 04:24)muza Wrote: [ -> ]hello, disable sub menu not working for me either, all addons up to date, thanks
I have fixed issue on last git. Update on repo will come soon.
(2017-03-19, 17:47)badplay Wrote: [ -> ]hey i want to update the skin but i get an update failed
Will not repost what I have already told so here is the link:
http://forum.kodi.tv/showthread.php?tid=...pid2543880
New Update 2.1.7 on repository :
• Changes for Kodi 18
• Fix setting to disable submenu
• Minor fixes
Hi!
How can I disable the new way to see lyrics and return to the old music fullscreen with the lyrics, the rotating disc and cover?
(2017-03-19, 23:40)Guilouz Wrote: [ -> ] (2017-03-19, 23:22)goibe Wrote: [ -> ]Hi!
No way to do that.
What a pity. Was a great feature.
Can I download a previous release with that feature? I deleted the old one after update to this one before I realize this missing feature in the updated one.
(2017-03-19, 23:53)goibe Wrote: [ -> ] (2017-03-19, 23:40)Guilouz Wrote: [ -> ] (2017-03-19, 23:22)goibe Wrote: [ -> ]Hi!
No way to do that.
There is no previous release for that. Video lyrics have been introduced since 2.0.3 (11 versions backwards). CD case with rotating disc are available when lyrics are not running.
